brake problem
i have a 96 bmw 318 ti . i have replaced the rotors and brake pads ,front and back. the problem is when i apply pressure to the brakes while driving , i can hear and fill thumping when braking .. could there be something else wrong with my braking. { a loud thumping noise when braking until i stop}
Check your tires. More than likely they are "cupped" or worn irregularly. This is usually caused by worn out suspension components and/or the car being out of alignment.
when u changed ure brakes, did you bleed the brake system?
i am sure that it is ok, but check ure abs too.
Current: 1990 BMW E30 325i 2004 Subaru Legacy 2008 Toyota Sienna LE Retired: 1978 Cadillac Fleetwood Brougham 1990 Volkswagen Jetta GL 1991 BMW E30 325i 2001 Honda Odyssey EX |
This same thing happened to me when I replaced pads and rotors.
Then I adjusted the emergency/hand brake as per the Bentley manual, and the thunking went away. |
