Old 04-16-2003, 01:45 PM
blade34609's Avatar
blade34609 blade34609 is offline
Chirping Gears?
Hi,
I just started driving stick and im 16 years old. I am starting to get pretty good at it. At little bit smother shifting gettin out of 1st though
I need help on how to clarrify the different answers people are telling me and myths on driving stick.
I have a 90' civic LX with a 5 speed tranny.
Will chirping gears wear out my clutch faster?
Some people have told me it will and some told me it wont.
What is defined as riding the clutch cause I heard it wears it out easier.
Also when I wanna come to a stop sign, light, or turn I like to press my brake then fully press my clutch and shift to a lower gear. Say im goin in 4th gear and I wanna turn so I downshift into 2nd gear. Thats ok to do right?
thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 04-16-2003, 02:08 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
chirping the tires once in a while is ok... but if its everytime you shift it will cause damage over time.
down shifting from 4th to 2nd is ok... i do it all the time.
riding the clutch is having part of the clutch pressed in while driving, this causes slip wich over time can cause preamature wearing.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 04-16-2003, 02:19 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Standard Mysteries...
Hello, and welcome to the wonders of the standard transmission!
Unless your car is very powerful (and it's not; I have the very same car with the wimpy D15 motor) the only way to 'chirp' is to rev up the engine while your foot is on the clutch, and then let out on it real quick. That is always bad and will damage the clutch. If you treat your clutch well, it'll last 150,000 miles before you have to replace it.
"Riding the clutch" is something grandmothers are famous for. They think the clutch pedal is a nice place to rest the foot. This will kill a clutch very quickly. Put your foot on the clutch pedal when you're taking off, or when you want to shift. Apart from that, rest your foot on the floor, not on the pedal and you won't ever be 'riding the clutch'.
I will also tell you this: Hondas are happier in the higher RPMs. They don't make much power below 3,000 RPMs. If you're going up a steep hill and your RPMs drop below 3,000, downshift. In fact, it's actually very hard on your engine to try to climb a hill with the RPMs too low. That's called 'lugging'. Lugging=Bad.
Yes, you should probably be downshifting to second or third to go around corners. If you're going around corners in 4th, and you're going less than 70MPH, you are probably lugging.
Now, did you know that once the car is moving, you can shift gears WITHOUT HITTING THE CLUTCH PEDAL?! This is one of those mysteries that will take you many years and much grinding to figure out. This is the way big trucks are driven. Truck drivers use the clutch when starting from a standing stop, and then don't use the clutch again until it's time to come to a complete stop. That's the way I drive my Honda!
But you are not ready for those mysteries yet, Grasshopper...
Flunky
Old 04-16-2003, 02:29 PM
blade34609's Avatar
Thanks for the info.
You guys have helped me alot.
What if your goin like 50 mph in 4th gear and I want to slow down for a turn to about 20 mph. Can I first press the brake pedal, then fully press my clutch and shift to 2nd and make the turn?
Thanks,
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 04-16-2003, 02:35 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
i used to be able to drive without the clutch in the mg but cannot do it in the civic
ok I got a question for you guys too while we are on this. when my car is cold its really hard to shift into first gear ... should I double clutch into it or is something on my car fucked up or what?
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
AF Premium User
Personally, I like to downshift through every gear. If I want to slow down from 50 to 20, I use the brake a bit, gear down to third, let out on the clutch and let the engine slow the car down, with no foot on the brake. The nice thing about this method is, your car is almost always in a useful gear. If something's coming at you and you want to speed up, you're already in gear; you hit the gas and get going.
Then again, practically everyone on this forum is always looking for excuses to speed up.
So: I like to downshift through every gear. That's my preference, not a rule.
Flunky
Old 04-16-2003, 02:37 PM
GTA's Avatar
GTA GTA is offline
Whee..
try to put it in 2nd first, but not let out the clutch and then move it to 1st.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 04-16-2003, 02:38 PM
Melt's Avatar
My mom does that all the time, but wont that eventaully wear out second gear also and ill have the same problem with that ... or what?
AF Bay Area Crew
AF Premium User
Hey, Melt!
What kind of oil have you got in your transmission? I use 10W-40, which means it's thin at low temperatures (like right when I start it up) and then gets thicker after I get it warmed up, by driving down the highway. If you have straight thirty weight, your oil will be thick when it's been sitting all night, and hard to get into first right when you start it up.
Nothing wrong with double-clutching, or anything else that keeps things from grinding.
Flunky
Old 04-16-2003, 02:40 PM
GTA's Avatar
GTA GTA is offline
Whee..
i dunno about wearing it out. its just the synchros arent lined up so when you do it it lines em up i think.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 04-16-2003, 02:41 PM
AF Premium User
I don't think it'll wear it out. Shouldn't harm anything if you're just using 2nd gear to make sure you are properly lined up to get it into first.
Old 04-16-2003, 02:47 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
I have a few points:
I got 168,000 out of my first clutch.... FerioSiR got 315,000 or some crazy ass mileage out of his
Not using the clutch wears out the synchros in our cars...rev matching is they key there, but it still puts some load on the synchros. I have a bad 3rd, and rev matching and double clutching really helps cut down on the grinding.
I don't usually put in the clutch when I am slowing until the engine is at 1000-ish RPM...just before you're going slow enough that the engine is still trying to make the car go but you have the brake on. If you push the clutch in as soon as you brake you have much less control, as Flunky said...you never know what crazy-ass peeps are doing around you, and with both feet pushed in you can't get to the gas and avoid their dumb-asses...also, that lets the weight of the engine take the load as you slow, taking some weight off the brakes...they'll last longer.
I usually downshift to about 3rd for things like traffic lights...then I leave the clutch out until about 20-ish MPH...which is 1250 RPM or so..then I push it in as I complete my stop.
There's my $0.02
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 04-16-2003, 03:14 PM
AF Premium User
Hey, SAstanley-
I got that rev-matching DOWN!
Flunky
PS-Only REALLY funky thing about shifting without the clutch is it totally freaks out the cruise control. If I've got the cruise control on, I can rev the engine a bit and take it out of gear, but then it screams all the way up to the rev-limiter, which is quite a surprise when I'm lost in my own thoughts on a long trip. Those poor engineers at Honda never prepared for someone to take it out of gear without turning off or deactivating the cruise!
Old 04-16-2003, 03:20 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
synchronizing the gears is a sweet trick my buddy can down shift and up shift all the gears without using the clutch, I can only do 2nd, 3rd and 4th, but I grind now and then so I dont do it much...Its so cool though haha
blah
Old 04-16-2003, 03:53 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
how do u shift without the clutch ? ive never tried that before because whenever i shift fast and like i shift faster than my foot can hit the clutch pedal, it grinds. so how to u shift without the clutch, im curious to know
Team Lonely Drivers
1975 Caprice rear end gear/rear end swap? Topless75 Caprice 3 03-10-2010 01:29 PM
Replacing rear end gears bigdaddyhill71 General Discussion 1 02-10-2010 10:10 AM
How do I know if I'm in too high a gear uphill? PenguinLust Cars in General 0 01-30-2010 12:44 AM
99 MC Gear Slip, Stalls when i slow down sully313 Monte Carlo 3 10-01-2009 12:52 PM
Chirping gears? blade34609 '88 - '91 Civic | CRX | Wagon | Shuttlee 37 10-16-2003 06:30 PM
