Old 04-16-2003, 07:49 AM
Integra14's Avatar
Integra14 Integra14 is offline
Send a message via AIM to Integra14
Cutting Wheelwells
iF I were to completely cut the wheel wells out.. would it loook ok, and wuld i be able to control the ride height..... OR could i cut the wheel wells off, then putty, and strene to make them higher...
IM Talkin bout the CHASSIS HERE, i will Camber and if needed, tuck the wheels inside..
Old 04-16-2003, 09:10 AM
nervestrikes's Avatar
nervestrikes nervestrikes is offline
Yes you can, but it could turn out to be allot of work. You might be better off just trimming the springs & spension and adjusting the arms to keep it steerable. If you don't care about being able to steer then don't even worry about any adjusting just cut away. I you look closely here in the third pic you can see I cut out the wheel well to make the car dropped more. I hope this helps.
Old 04-16-2003, 12:50 PM
Camber's Avatar
Camber Camber is offline
Send a message via AIM to Camber Send a message via Yahoo to Camber
Thats actually A very good idea, The idea of Bending styrene higher up! I may need to try this!!
Old 04-16-2003, 01:10 PM
Only thing is when you bend it you must heat it up first far from a flame or even boil it and it will bend easily then to set it once you got the position you like dip it in ice cold water. Works pretty good, but play with some strips first before using the real thing because of how thin or thick the parts maybe. Let me know what you think once you have tried it.
Old 04-16-2003, 01:22 PM
fullbloodchop01's Avatar
fullbloodchop01 fullbloodchop01 is offline
Send a message via AIM to fullbloodchop01
woa, boiling styrene?! never herd of that, anyone have any experiences with that?
Rui
(modeling) = Click Here
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
The cut-out remote cut-up kits...where? -cy- Camaro Discussions 13 07-22-2005 06:12 PM
Wheelwell/body separation deadBird Grand AM 5 04-19-2005 03:04 PM
90 VW Fox cuts out HELP - when warm does this death / cut out / diesel / chokeded out jamandrew General Discussion 5 04-14-2004 11:53 AM
fuel cut or ignition cut on MR2 turbo???? TEAM KLR MR2/MR-S 9 01-28-2004 01:20 PM
