Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-22-2010, 01:38 AM
wednesday513 wednesday513 is offline
93 camry knocking issue
93 camry, 4cyl 2.2, started knocking slightly due to lack of oil, ran low and the light never came on. car stalls, add 4 quarts oil and ran engine for approx. ten minutes, not driving, just sitting idling around 1500 rpms trying to get the oil to go through. let off the throttle, car stalls, does this about 3 times. i hold the throttle around 2000 rpms for a couple of minutes, temp guage goes all the way up, shut it off, pop the hood, and the radiator explodes in my face. let the car sit for about 20 minutes, start and hold the throttle around 2000 while adding luke warm water to radiator. after water runs through car will stay running, idling hard and knocking lowly. i did not drive it at all after it stalled out the 2nd time. i shut it off and had towed home.
can i get away with new rod bearings and an oil pan gasket or a rebuild/replace. also how much should parts and labor run me after market approx
Old 03-22-2010, 09:13 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 93 camry knocking issue
It would seem that you had better look at the cylinder walls, piston skirts, cams, bearings, etc before you opt for a cheap solution. It is impossible to know how much damage was done.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
