Old 04-14-2003, 12:50 PM
Touge180 Touge180 is offline
Rod Knock
what does this sound like cause i think i have one when my car isn't warmed up in the morning and i drive i here like this chattering noise from the engine but when the car warms up it goes away.
Old 04-14-2003, 12:55 PM
turbcivic's Avatar
turbcivic turbcivic is offline
I don't think that is rod knock cause then you would hear it all the time.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 04-14-2003, 01:01 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
its your valve tappits from the sounds of things, you need to readjust the clearences and torque em down to spec ... had to do this on my car the other day.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 04-14-2003, 01:04 PM
i don't have any idea how to do that could you give me details on how to
Old 04-14-2003, 01:27 PM
Melt's Avatar
Im too much of a n00b to explain it ... cause my dad called over the mechanic cause we couldnt figure out how to get the engine to top dead center ... but anyways, someone here will be able to show you the way
AF Bay Area Crew
Old 04-14-2003, 03:27 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Knock, knock, knockin on heaven's..block.
Knock, knock!
Who's there?
Rod.
Rod who?
Rod bearing!
Ha ha ha haaa!
I have too much free time at work.
Flunky
Old 04-14-2003, 04:33 PM
Melt's Avatar
haha .... what do you do for a living?
AF Bay Area Crew
Old 04-15-2003, 01:21 PM
turbcivic's Avatar
This is an idea on how to do it, go get a service manual for the complete way. Jack the front of the car of the ground and put a breaker bar on the crank pulley bolt. Rotate the engine to top dead center by turning counterclockwise. Use a feeler gauge and a valve tool, looks like a combo screwdriver and wrench. Adujt so that you restiance on on the guage. Go to next cylinder 90 degrees off and do over again.
Old 04-15-2003, 04:44 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
isnt there some way you can like put your thumb in a plug wire hole and turn the crank and when it makes a psssst noise that means its TDC? i dunno i think i recall seing this done on a tv show
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-15-2003, 08:37 PM
Cjz89civic's Avatar
Cjz89civic Cjz89civic is offline
AF Premium User
Send a message via AIM to Cjz89civic Send a message via Yahoo to Cjz89civic
This noise can also be cause not by the valves but by the oil being to high viscosity like 20-50 and its really cold out. It is dry running if the oil is the problem, also low oil not a little but alot like 1-2 quarts low will cause this sound also. Just some input...
Mods: D16Z6 Turbo'd P28 ecu and Greddy emanage for fuel. FWD tire smoker
My first Civic love Died from 92 year old Fart not watchin out.
Old 04-16-2003, 11:59 AM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
The first thing I'd do is change the oil....Fresh oil does wonders.
Sometimes when it is really cold out, my valves ping for 10-15 seconds while the cold/thick oil works its way up. Also, my car has 210,000 miles on it, so it burns a little bit too. I know it is time to add a quart when I hear the valves tinging
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 04-16-2003, 02:21 PM
myk888 myk888 is offline
Send a message via ICQ to myk888
Talking
a how to on the adjusting the valve tappets would be nice!
Rod Knock? NoviceAss Rodeo | Passport | MU 5 11-18-2009 10:55 AM
ROD BEARINGS has anybody tried? Chuckmonster Caravan | Voyager 1 07-27-2009 07:50 PM
1996 chrysler cirrus. knocking, but not rod knock or lifter cool_69aa General Discussion 0 09-06-2008 05:24 PM
Hi, I have a 99' 3.5 with rod knock 29k can you replace rod bearings in car? jimg300 Intrigue 1 11-11-2003 09:28 PM
Rod Knock 4GZChatch '88 - '91 Civic | CRX | Wagon | Shuttlee 8 05-08-2002 06:25 PM
