Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-04-2009, 08:46 PM
NoviceAss NoviceAss is offline
Lightbulb Rod Knock?
Alright, I have a 1999 Honda Passport (Isuzu Rodeo) with a 3.2L V6 engine, it seems to be burning oil as i was TWO quarts low when I heard a knocking, I changed the oil immediately and now there is a slight knock which seems to come from the engine at 1500 rpm only, not at idle. The interesting thing is, today I was annoyed enough to just drive down my street in reverse (no knock in reverse) and the knock lessened in sound, and also only occurs now at 2500 rpm in drive. One last part of the scenario, whenever I shut off the engine at idle(no knock) there is one knock, as if something is falling. So is this rod knock or not? Also why has it started to occur at a higher rpm and not nearly as loud?
Old 11-04-2009, 11:14 PM
Cat Fuzz Cat Fuzz is offline
Re: Rod Knock?
Check your timing belt tensioner. It's on the right side of the engine under the timing cover. You can usually get the right side timing cover off pretty easily.
99 Rodeo LS 3.5L Stroker V-6, 4wd, 31x10.5x15 2 inch Trooper lift, Aisin manual hubs.
03 GMC Envoy XL SLT 4x4 5.3L V8
Old 11-05-2009, 08:42 PM
sassee's Avatar
sassee sassee is offline
Re: Rod Knock?
A bad rod/rod bearing will knock ALL of the time, not just every now and then. Check your belt tensioner. It's a common issue with these.
also, I have no idea what oil you're using but a quality diesel service oil (API CJ-4 rated) will do great in this engine. I use Rotella T but any major oil company diesel oil will be good. The diesel oils still have the detergents in them that will help keep your oil passages clean. Lubrication is critical on the motor so help it out! You won't regret it! Keep check on your oil level. These engines do use some oil and a quuart or 2 between changes is VERY common! (some go thru more)
2000 Nissan Xterra XS
1989 Isuzu Trooper with a mod or 2
1998 Isuzu Trooper 3.5 with a 5-speed with a mod or 2
1985 Chevy K-10 with a mod or 2
Old 11-07-2009, 11:15 PM
Re: Rod Knock?
Well bad news on this front, the sound has become frequent even at idle, it'll be in the shop in a week. I've got an honest mechanic in mind so I will let you know whats going on as soon as its taken apart.
Old 11-09-2009, 06:15 PM
sassee's Avatar
Re: Rod Knock?
Steady knock at idle usually means bearing. (or sometimes wrist pin)
Old 11-18-2009, 10:55 AM
intimadatorsquizz intimadatorsquizz is offline
Re: Rod Knock?
my 95 was hammering like crazy it was the belt tensioner it was stuck out so changed out the belt/waterpump and tensioner and idler and new drive belts for $260.00 all better now and purrs like a kitten.and yes they do use oil so keep an eye on it.
Tags
knock , lifter , rod , transmission
