| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
Stoopid Check Engine Light
So, the ECU spit out these codes to me
0705 EVAP control sys 0903 EVAP canister vent control valve 0304 Knock Sensor Has anyone ever gotten these codes and had to replace them? Get them Replaced? Can anyone tell me about the cost it'll take to repair the stuff? Thanks for the help -spaz |
Look behind the drivers side rear wheel. The Evap system is located under there. You'll see the canister and the valve. The valve gets contaminated by crud the rear wheel throws up. You can take the valve out and clean it up with WD-40 to get it functional again. The valve is the unit with the electrical connection on it.
Once you get the valve working, clear the error codes and see if your KS code comes back. The KS code means your getting a signal from your KS sensor thats out of the acceptable range. It does not necessaraly mean the KS is bad, it could be indicating you have excessive ping and knock. Make sure your car is running correctly before you waste money on a new KS sensor.
![]() 99 SE LIMITED - A few changes here and there but most of all SPOTLESS! |
Just because offense is offered, does not mean you have to take it. |
Unless the sticker on the pump is lying, I havent put anything less than 93 in for the last six months since I moved to jersey.
how's the heat, boingo? |
