Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-17-2010, 08:47 AM
Demoman442 Demoman442 is offline
98 Camry dead hole
98 camry 2.2 # 3 cyl goes dead after warm up,but is firing,I suspect bad injector Is it possible to switch # 2 #3 to see if the miss follows? Thanks in advance.
Old 03-17-2010, 11:35 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: 98 Camry dead hole
Yup, Thats not a bad way to do it at all. Its a lot easier to use an injector testing but not worth the expense for a one time use. There where plenty of times I would swap injectors or if possible pull the rail and see if the injector was firing while cranking.
Old 03-17-2010, 02:27 PM
Thanks! Will post results tomorrow.
Old 03-18-2010, 07:47 AM
Removed valve cover, 2 13mm bolts that hold the rail, switched # 2 and # 3, started up with scanner attached miss went to # 2 cyl, Got a rebuilt injector from A Zone $69.00 "It's a car lot car" runs smooth now. happy customer!
Old 03-18-2010, 10:31 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Good job! Thanks for the feedback.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
