Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-11-2010, 06:45 PM
primal1 primal1 is offline
99 obs tahoe 5.7 wont start
i was on my way to work today when my truck shut down. i tried to restart it, but it would only crank. after i got off work, i went and checked a few things to try and diagnose it. i get 60 psi at the fuel rail. it leaks down to 53 after a wile. and i checked for spark at the second cylinder from the front on the drivers side, and it is getting good spark. it is not even trying to sputter. it has been giving me code p1441 for a long while. but i'm also getting 1351 code wich is high voltage at ignition. would this be my crank positioning sensor. is there a way to test a crank sensor.
Old 03-11-2010, 08:13 PM
777stickman 777stickman is offline
Re: 99 obs tahoe 5.7 wont start
Is it the CKP? Maybe but most likely not according to my C/K service manual for P1351.
If there was an issue with the CKP it would most likely set a specific code for that. (P0336,337,338,339).
P1351 has 18 trouble shooting steps. Only 2 replacements. ICM & VCM and a lot of circuit testing which includes checking connectors at the ICM & VCM for corrosion and/or?
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-12-2010, 05:27 PM
well, its not the ckp.
Old 03-12-2010, 08:16 PM
j cAT j cAT is offline
your vehicle has distributor issues ....open it up and see whats going on in there !
ckp is not your problem with that dtc....you got....
ckp bad no spark....
Old 03-12-2010, 08:26 PM
9502chevy 9502chevy is offline
had this same problem a couple weeks ago and danced around the dist. because i thought spark looked good at plug also. PULL THE CAP AND ROTOR AND LOOK. stick to visual basics and don't ass u me anything.
Old 03-20-2010, 07:42 PM
rr7774 rr7774 is offline
how do u remove the ignition switch 99 tahoe
Old 03-21-2010, 09:40 AM
make your own posting ,,,give vehicle details ,,like new old body style etc...
give your detailed explaination on your issues ..this will get the most /best response..
