Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 02-27-2010, 03:44 PM
phantom1131 phantom1131 is offline
95 non odb2 16 pin dlc
is there a way to get codes by jumping?
here are the available pins-2,4,5,9,16
can't find anything in Forum or Google search
Old 02-28-2010, 08:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 non odb2 16 pin dlc
Some 95 PCM require a special scanner adapter plug in to read out or get codes.
But a 16 pin connector sounds like OBD11.
What engine and engine code?
http://www.troublecodes.net/OBD2/
MT
Old 02-28-2010, 08:53 AM
MT-2500's Avatar
AF - Advisor
Have you tried a OBD11 scanner on it?
MT
Old 03-01-2010, 12:48 AM
took it to autozone and the reader they had would not work
there is no test terminal available on my dlc so i'am assuming it cant be checked via the old paperclip way,was just wondering if someone knew different
1995 gm was in the middle of changing over to obd2 so some vehicles have the obd2 dlc but give obd1 codes
i'll try advance auto and see if they can read it
Old 03-01-2010, 08:33 AM
MT-2500's Avatar
AF - Advisor
Does the diagnostic connector look like this?
MT
Old 03-01-2010, 11:26 AM
sure does...here is some stuff from that page that i was talking about..the bridge they talk about is what i am trying to figure out if i can do but i do not have terminal 6 available so it has to have a scanner
Pin 2 - J1850 Bus+
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 6 - CAN High (J-2284)
Pin 7 - ISO 9141-2 K Line
Pin 10 - J1850 Bus
Pin 14 - CAN Low (J-2284)
Pin 15 - ISO 9141-2 L Line
Pin 16 - Battery Power
Some 1995 GM vehicles have the 16-pin connector but have accessible OBD-I codes. Check the underhood emissions sticker to confirm, and if yours is OBD-I, the codes are accessed by bridging terminals 5 and 6. If your vehicle is OBD-II, a scan tool or computer is required to access the codes.
here is my dlc
