P0410 Secondary Air Pump Malfunction
I know this topic has been dealt with in the past but I'm do for inspection again and last year the mechanic tried fixing the problem, but could not, so I got a waiver after being charged 500 dollars. I don't want to pay for this again. And from the research I've done, this problem is difficult to get rid off. I want to get the code deleted from my ECM. Does anyone know of any companies that will do this or of any other ways around this?
2002 Grand Prix 3.8L |
Re: P0410 Secondary Air Pump Malfunction
Drive it to MN, I'll delete the code out of your PCM for free!!!!
Seems I remember the 3800 GP's having issues with air pump duct work being mounted too low causing water to get in. Which really isn't a major deal untill it freezes and ruins the pump. Bob or Rich may be able to give you more info. I do not have an air pump on mine, so I lucked out!!!
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
How many miles on this GP and do you still have the original CAT converter?
I recall some P0410 issues were caused by the CAT converter or were 02 sensor problems if the air injection pump and control valve were replaced but did not fix the issue.
There's about 74000 miles on it, and the cat was changed about 2 years ago as part of a recall.
Any other details or history you can give us. Was the air injector pump and control valve looked at or replaced? Front 02 sensor?
The air pump is not flowing the right amount of air into the exhaust so P0410 will set. There are two tests run. See below. Quote:
Can you hear the pump run? If not check all the fuses.
It doesn't sound like it's turning on anymore but the fuse isn't blown. It was running for many months and i still had the code, so tht isn't the problem. I want to delete the code from the computer. How can I delete it?
You'll have to find someone local that can delete it or send the PCM to someone that can delete it. A dealer might do it for you if its not required in your state.
