Old 04-13-2003, 05:08 AM
Integraboy617 Integraboy617 is offline
Send a message via AIM to Integraboy617
Turbo? or Na
i live in boston mass. so the winters are alwys bad here. so i am thinking about na instead of a turbo or super charger. i love my car and i would like to know what i should look into in terms of horsepower but at the same time not killing my engine life. looking to spend around 2-3k. btw this is what i had planned for my 00 gsr.
00' Gsr (already installed)
Greddy Evo Catback
DC DAC air charger
(planning to get)
skunk 2 intake manifold
dc sports 4-2-1 header
skunk 2 stage 2 cams
skunk 2 cam gears
NEED OPINIONS PLEASE
Old 04-14-2003, 01:16 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
I would have to agree with you on the GSR. If I were you I would just go with a All Motor Build. GSR's built up can be very quick. Just get the head done and see how much of a diffrence it makes.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 04-14-2003, 01:39 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
The mods you listed that you want to get are a good start. With a good enough cam upgrade, you can boost hp by as much as 25-30 hp. Also look into upgrading your fuel system as well, get an adjustable pressure regulator, upgrade your fuel rail, maybe get some Type-R injectors if they are bigger than the GSR ones, and also maybe consider a larger bore throttle body to go along with the Skunk2 intake manifold. As time goes on and you can afford it, port and polish the head, and upgrade your valve springs and retainers, then get better pistons, and eventually better rods as well. If I recall, the GSR motor has great potention as an N/A powerhouse.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 04-16-2003, 01:07 AM
tenzoracerevovii tenzoracerevovii is offline
i agree 100% with the above post, but don't forget to upgrade the transmission with all those mods. a lightened flywheel and a more aggresive clutch will help you put all that power to the ground. also a type-r final drive gives you shorter gears for quicker acceleration also. maybe an lsd to go in between those axles eh? or maybe you can just spring for the type-r tranny w/ lsd. all depends on how much money you have. dont forget about the suspension and brakes!!!! and most of all have fun and fill us in!!!!!
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Turbo Turbo...Im craving Turbo! Cavyfamous97 Cavalier 51 08-14-2007 05:25 PM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi JDM Motor & Parts info/chat 8 01-21-2006 02:11 AM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi N2O | Turbo | Superchargers 5 01-08-2006 11:40 PM
Turbos Turbos Turbos 4-THGENH24LUDE Prelude 8 12-23-2004 05:31 PM
Turbo, Turbo, Turbo SI_CivicGyrl Forced Induction 6 02-18-2004 02:47 PM
