Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-28-2004, 11:36 PM
SI_CivicGyrl SI_CivicGyrl is offline
Turbo, Turbo, Turbo
I Have a 2000 SI and I want to turbo charge it I was thinking abot either a rev hard, drag or garrett turbo, which one is best for my car and is it okay to run 8psi on stock interanls or should I port and polish and get a new camshaft? Any feedback would be helpful.
Old 01-29-2004, 06:13 AM
b16aturbo b16aturbo is offline
um.. i would suggest getting the Drag turbo kit.... the t04/t3 Ball bearing turbo... i think you should sleeve or buy a dart block to make sure... hope i helped..
Old 01-29-2004, 09:03 AM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Turbo, Turbo, Turbo
a b16a will be fine running that lil boost stock as long as your motor is in good shape. for 8psi spending 2g on a dart block is a waste. P&P would help just as well so if you can swing it get it. I don't think new cams would help you at all at such low boost but if you up the boost skunk2 crower crane all make turbo cams.
Old 01-29-2004, 05:10 PM
boosted331 boosted331 is offline
Good god why do people like you try and give advice to people when they're totally clueless? The ballbearing option on turbonetics turbos is another 600 dollars, which is a waste of money. So is sleeving, and for sure so is a dart block when she wants to run 8 pounds of boost on a stock motor Maybe she should run 22 psi with a dart block so she can run high 12's like you're going to Get a maxrev kit with hondata from wired speedlab, 800-947-3380 ask for kyle. Bolt it on, get the hondata tuned, and go.
Old 01-29-2004, 06:17 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
Re: Re: Turbo, Turbo, Turbo
ok why is a bb turbo a waste of money? it will help wid spoolin the turbo quicker.. i say dont get the bb tho u arnt puhing crazy boost or nehting only 8psi i say get the kit and focus on fuel managmnet.
you can get up to 230whp if you tune properly, my friend has a b16 turbo and makes 230whp on stock internals..
good luck
1
Shift_BOOST
97 s14
Old 01-29-2004, 08:10 PM
maxspeedhonda's Avatar
maxspeedhonda maxspeedhonda is offline
Send a message via AIM to maxspeedhonda Send a message via Yahoo to maxspeedhonda
Re: Re: Re: Turbo, Turbo, Turbo
good luck
1
I'll be making close to 300whp on a stock b16a block as soon as I fix my wastegate prolems. Of course, I do have a project on the motor stand in my garage shooting for 400+ whp.
Old 02-18-2004, 01:47 PM
Thanks for the help. I will be going with the fmax turbo kit becuase its the most complete, and they said it will give 250hp at 8psi
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
