Old 04-13-2003, 02:05 AM
Deejay27's Avatar
Deejay27 Deejay27 is offline
Question Removing Tamiya Primer....
I really screwed up painting my F1 so I went ahead and stripped the Tamiya paint that I sprayed on (rubbing alcohol). Ofcourse the Tamiya primer underneath is not coming off. Will "Castro Super Cleaner" take the primer off? Any suggestions on what I should use to remove this stuff? Thanks.
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 04-13-2003, 04:53 AM
christofurr's Avatar
christofurr christofurr is offline
Re: Removing Tamiya Primer....
Just a question. Why do you want to take the primer off? You could just sand it back, and reuse it again for the respray, couldn't you?
Old 04-13-2003, 06:04 AM
Deejay27's Avatar
When I stripped the paint off it left a mess on the primer. I would have to sand too many pieces just to re-spray. It would be a lot less time consuming/labor intensive to start from scratch plus I would just feel better if I had a "clean canvus" to work on.
Jimmy
Current Project
Completed Projects
Old 04-13-2003, 06:23 AM
daggerlee's Avatar
CSC will definitely take off the primer. What color are you spraying? If it's a color that isn't affected by the base coat (not red, blue, yellow, white, etc.) you can just sand the primer smooth regardless of how crappy it looks and respray.
Dan
Old 04-13-2003, 10:43 PM
chaos's Avatar
chaos chaos is offline
AF Premium User
Is there anything else apart from CSC that would strip tamiya primer cos I haven't been able to find it here in Australia? The body has been sitting in brake fluid, but the primer just ain't coming off?
If I were to sand it - would grit would you guys suggest?
Is anyone having trouble finding white Tamiya primer? BOOSTD Car Modeling 6 05-05-2003 10:42 AM
Alclad II over Tamiya Primer and Tamiya Synthetic Laquer? Deejay27 Car Modeling 11 04-23-2003 05:59 PM
Tamiya primer Luka3000gt Car Modeling 0 10-03-2002 08:18 AM
Tamiya Primer GTRRR Car Modeling 7 10-01-2002 10:35 AM
Gray Tamiya Primer hAnGoOkNoM Car Modeling 0 04-07-2002 08:59 PM
