Old 04-12-2003, 11:58 PM
AlwaysMovin AlwaysMovin is offline
Question Installing 4 point harnesses?
Couple weeks back I posted asking if anyone knew how to convert from door mounted seatbelts to pillar mounted seat belts. Come to find out this would require cutting and welding pieces, which I have neither the time no skill currently to do. So I figure I will be better getting 4 point harnesses maybe. However what does installing these require??? Anyone done???
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello.
My Home Page: Under Heavy Construction
Old 04-13-2003, 12:44 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
I just installed 3-point harnesses in my hatch and removed my door-mounted belts. Installation was really easy, and relatively cheap. Unless you are planning on doing a bunch of autocross and the like, you should just stick with 3-point harnesses. For one, they're a little easier to install. The ones I have are retractable so that you can still get at your glovebox or whatever without having to take off the belts, but I don't think they make 4-pointers with retractors. Anyways, here's my thread about my installation with pictures:
http://www.automotiveforums.com/vbulletin/t97588.html
Old 04-13-2003, 07:22 PM
Talking
Those 3point harness look nice and quite a bit easier to install. I definately leaning in that direction now. One question though, what exactly is the C-pillar you were refering to?
Old 04-14-2003, 10:32 AM
ci5ic's Avatar
Here's a pic to explain the pillars:
The pillars are the supports that hold the roof up basically. The "a" pillar is the foremost supports on either side of the windshield. The "b" pillar is the one in the middle, at the rear edge of the door. The "c" pillar is the one at the rear of the car. This is where I wanted to mount the belts to. There is a hole there where the rear seat-belts used to be, so normally the harnesses would bolt right in, but the retractable belts have to be mounted a specific way which isn't possible on the C-pillar without having some kind of bracket made or something.
Old 04-14-2003, 12:48 PM
Ok , excellent. Thanks ci5ic.
installing aftermarket cd player jwhite85 General Discussions 3 03-30-2009 10:52 AM
installing five point harness RA64 Engineering/ Technical 7 07-05-2006 10:15 PM
Fitting 5-point harnesses freakray Car Modeling 12 11-27-2002 09:57 AM
4 point harnesses Santas90Si '88 - '91 Civic | CRX | Wagon | Shuttlee 4 10-26-2002 03:12 PM
5 point harness.... DaddyFatSacks Impreza/9-2x/Outback Sport 0 09-24-2002 11:10 AM
