Old 04-12-2003, 08:10 PM
pascualjr pascualjr is offline
94 Limited's air suspension problem
I've had this problem for the past few years now and I have no idea what the solution could be. The compressor for the DynaRide air suspension keep running every so often for a duration of 5 to 15 seconds. This is when the car is at a standstill, parked in the garage. The frequency seems to be hourly. About a year ago, I had my mechanic replace all of the shocks/struts including the rear units. However, the compressor cycling has not stopped. My mechanic checked it and found no air leaks. Since the car is a daily driver, I can't afford to leave it with my mechanic for any extended amount of time to troubleshoot. Since this problem hasn't really affected the performance of the car, I never really tried to resolve this problem; until now.
Any help/suggestions would really be appreciated.
Thanks!
Old 06-08-2003, 01:55 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
I'm gonna say worn out shocks, they arent holding the car up, and the leveling control raises the car, only for it to seep back down again.
Old 08-21-2003, 02:19 PM
gonzoflat gonzoflat is offline
Re: 94 Limited's air suspension problem
Thanks!
I have the same issue with my 94 park avenue, have you out anything recently?
Old 08-22-2003, 07:39 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Spray a soap solution on the plastic air lines I am sure you will find a leak!!!
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
air suspension problem i think kmichael30 Continental 1 03-30-2005 08:08 PM
02 Bravada Air Suspension Problem kenm Bravada 3 01-21-2005 08:50 AM
Poss. fix for Air Suspension Problems!!! Y2KGTA Town Car 1 10-10-2004 07:41 AM
95 Windstar Air Suspension problem vlj9r Windstar 9 06-06-2004 01:55 PM
Air Suspension problems ironleg LeSabre 0 05-22-2004 04:04 PM
