Go Back   Automotive Forums Car Chat > Toyota > IS200/IS300/IS350/Altezza
Old 02-14-2010, 08:43 AM
kevinsteele kevinsteele is offline
IS300 airbag light on
I have 2002 IS300 with airbag light on, can someone tell me how to check codes and reset it or do I have to have a scanner to do this?? I was wondering if it can be done with a wire and counting flashes??
Old 01-14-2013, 08:03 AM
davidbowie davidbowie is offline
Re: IS300 airbag light on
Becky, I would use a scanner. As you know, there could be many reasons why the airbag light is on but I would not want to be in an accident and find that my airbag did not deploy because of a malfunction.
I would take it to a trusted mechanic to run codes. Could just be the seat belt pretensioner which is cheap. resetting the code is like kicking the can down the road and it will come back eventually.
Hope this helps.
David Bowie
Old 01-14-2013, 10:42 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I doubt the problem still exists after three years. Check the date of the post before responding.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
