Old 02-08-2010, 10:46 PM
owen5454 owen5454 is offline
2001 sonoma 4/4 not working
When i try to enguage the 4 wheel in hi or lo all that happens is i hear a click up fron but nothing enguages, please help any suggestions would be appriciated
Old 02-09-2010, 08:13 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 sonoma 4/4 not working
What transfer case.
STD or AUTO4W button on shifting panel?
Any lights flashing or on?
Does front drive shaft lock in?
MT
Old 02-09-2010, 11:01 AM
Originally Posted by MT-2500 View Post
What transfer case.
Its the electronic buttons on the dashboard,the lights flash for about half a second then stays lit up, and thats on hi n lo i dont beleive the front drivshaft locks in because i was stuck in the snow and the front wheels wouldnt spin at all
Old 02-09-2010, 01:53 PM
MT-2500's Avatar
AF - Advisor
What transfer case?
233 or the AUTO4W?
Have you felt the drive shaft for locking in?
MT
Old 02-09-2010, 02:56 PM
What transfer case?
233 or the AUTO4W?
i havent felt the driveshaft ill try that n keep u posted. How can i tell the differance between the 223 and the AUTO4W? I can get underthere and look but im really not sure how to tell the differance
Old 02-09-2010, 03:08 PM
MT-2500's Avatar
AF - Advisor
The Automatic 4W has the Auto4W button on it.
On back of transfer case there is a ID tag.
For a 233 you can ground pin 13 and get codes.
The Auto4W requires a transmission/transfer case scanner to test and get code.
For a 233 go to this link.
http://www.automotiveforums.com/vbul...d.php?t=572914
MT
Old 02-10-2010, 01:31 PM
thank you that was deff helpfull but theres about a foot of snow outside so i cant get under there at the moment, do yoounthink this could be an issue of low fluid? i just bought the truck and i have a warrenty but its a $250 deducable and i was just trying to save somr money if possible
Old 02-10-2010, 03:05 PM
MT-2500's Avatar
AF - Advisor
Fluid level should always be checked.
What transfer case do you have?
Any transfer case codes?
MT
