Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-30-2010, 03:11 PM
hammerhead1905 hammerhead1905 is offline
2003 GTS Spyder Maintenance
I know what the manual sez but what should I have done at the 120K mark (currently at 119K). I haven't had any problems at all with this car and have pretty much stuck with changing oil every 3K and that's it. I'm thinking of having the dealer give it the once over but I don't want to take it in the shorts for unnecessary maintenance.
On the one hand I'm afraid to do anything since it has run great till now but on the other hand I don't want it going T*TS up since I haven’t done something.
Any suggestions are appreciated.
Old 01-30-2010, 03:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 2003 GTS Spyder Maintenance
Moved from E/T/L forum.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-30-2010, 10:31 PM
RahX RahX is offline
Have you done anything besides changing the oil? Timing belt, trans service, coolant service? 4 or 6 cylinder?
Old 01-31-2010, 11:51 AM
Coolant and trans fluid changes and flush. Nothing with the belts or trans that I recall. It's a 6 cyl.
Old 01-31-2010, 06:15 PM
I'd get the timing belt replaced asap. You're way past due for a tuneup also. You might as well change the valve cover gaskets while you have the intake off.
Old 02-01-2010, 08:19 AM
Thanks
Old 02-01-2010, 06:54 PM
Just curious what's the big deal with the timing belt and should I have the other belts done as well?
Old 02-01-2010, 11:59 PM
The timing belt connects your crankshaft to your camshafts. If it breaks your engine will not run and there is a chance it can bend some valves and it might damage your crank sensor. If you haven't replaced your drive belts, you should change them when the timing belt is done since they will be off of the engine anyway.
Old 02-02-2010, 10:53 AM
Great, thanks. I'm lined up for all belts, and the dealer suggested a "throttle body , air induction and fuel injection system cleaning ($100)”. Total for all will be about $900. He also said they wouldn’t have to take the intake off so I’m skipping the valve cover gaskets. Bottom line about $900. Most off that’s on the timing belt.
Does that sound reasonable?
Old 02-02-2010, 06:03 PM
It sounds a bit high to me. Did they recommend spark plugs?
Old 02-03-2010, 08:04 AM
Nope. Which part sounds high?
Old 02-03-2010, 02:59 PM
They didn't reccoommend spark plugs. The cost for the timing belt was about $600. The other belts about $150. Does that sound high?
Old 02-04-2010, 07:49 AM
The timing belt replacement was about $600. They didn't suggest spark plug replacement> Do you think $600 is high?
