Old 01-27-2010, 12:26 PM
gonzoblazer gonzoblazer is offline
Oil drip...oil cooler lines?
i'm pretty certain my oil cooling lines are weeping at both ends of connections. i would like to replace them but cannot find these parts to do so. does anyone have any suggestions where to look and estimated price? also while i was scraping grit and grease off with putty knife, i noticed that the "aluminium housing" that the oil filter screws onto and two oil lines leave, is hanging by two of three bolts. one of the holes has completly snapped off and the other has a crack in it. does anyone have the technical name for this "aluminium housing"? its a 98 LS 4.3l, 2dr vin"w" 5spd manual nv3500.
Old 01-27-2010, 01:42 PM
cyclopsblown34 cyclopsblown34 is offline
Re: Oil drip...oil cooler lines?
Call your local Shivalay stealership parts department. They can set you straight on the spin on filter/hose adapter and hoses, they are a relatively cheap fix, at least on my old Suburban they were. It was less than 100.00 if I remember right.
Good luck,
Chip.
Old 01-27-2010, 02:13 PM
tahnks chip. now my next question, is this a job that can be performed by someone whose mechanical experience thus far has been oil changes, shocks, water pump and idler pulley?
Old 01-27-2010, 03:06 PM
old_master's Avatar
Advisor/Moderator
The aluminum block is called the "remote oil filter mount". Check out your local boneyard for a replacement.
Simple enough job and can be done without special tools. Don't bother with the dealership lines. If you buy the lines at the dealer, you'll get the same lines you have now, and they'll leak just like the lines you have now!
Most auto parts stores have replacement lines made by Dorman. They are cheaper, better quality and will last longer than the GM lines, but eventually they will leak too.
If you want to do the job one time, your lines can be modifed for about the same money as the repplacement lines, maybe less. Here's how: http://www.automotiveforums.com/vbul...d.php?t=764277
Old 01-27-2010, 03:23 PM
wow, how-to is pretty straight forward, thanks. so when i get these replacement lines i also need to replace the housing where they and the oil filter connect. i just don't know the actual name of that "aluminium housing"is. got any idea?
Old 01-27-2010, 03:27 PM
old_master's Avatar
Advisor/Moderator
You have to know how it works,
to figure out why it doesn't.
