Old 01-23-2010, 04:38 PM
auto trainy auto trainy is offline
Question 2001 fuel injection
I'm looking into buying a noid light kit for my 2001 Le Sabre but don't know what type of fuel injection this car uses,can anybody help?
Old 01-23-2010, 07:03 PM
Jrs3800 Jrs3800 is offline
Re: 2001 fuel injection
Its an SFI system...
Fuel injectors and connectors changed in the 01 area...
Not sure what answer you are really looking for...
Old 01-24-2010, 10:25 AM
I'm looking to find which noid light will fit my 2001 3800 series 2, Thanks
Old 01-24-2010, 11:59 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Are you an amateur auto repairer or pro?
The OTC/SPX company makes fuel injection system pulse testers and noid light kits that covers many fuel injection systems so it should cover GM PFI, Ford TBI, Geo TBI, Bosch PFI, GM TBI, GM SCPI, Bosch 2 and Multec 2. See link below. Also, these kits come with an extension cable. Personally I wouldn't waste any money on a noid light kit but they come in handy if you make a living off of repairing cars. I use a simple 12 volt test light with prod or a digital multimeter.
Click here
On typical GM fuel injection systems one side of the fuel injector coil is hot when ignition is ON and then the PCM provides a low on the other side of the coil at the right time and duration to make the injector spray so you get a pulsing effect with what ever test equipment you use. Better known as fuel injector pulse width modulation.
Timeslip 08/12/06
AF Community Guidelines
Old 01-24-2010, 05:12 PM
I know I've seen it before but what 12 volt lamp would I use? or at what range would I use my fluke meter?
Old 01-25-2010, 09:20 AM
maxwedge maxwedge is online now
A990 racer
Noid lite can be bought for 15.00 at any Carquest store.
Old 01-25-2010, 07:19 PM
Thank's for all the info,hopefully I never have to use it but its always good to have.
