Old 01-22-2010, 09:29 PM
chubcobear's Avatar
chubcobear chubcobear is offline
1995 Air Blend Actuator
It was not a matter of waiting for a ECC fault to reset, it turns out that I have a faulty Air blend actuator. I see that it is located behind the glove compartment and I have ordered a replacement. Any tips for me before I try to get my big hands in there to replace it? Perhaps someone has done this job before? Thanks.
Old 01-23-2010, 02:05 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 1995 Air Blend Actuator
Click Here
Old 01-27-2010, 09:30 PM
chubcobear's Avatar
For a 1995 Buick Lesabre, I used/replaced a AC/Delco Part # 15-71923 Air Blend Actuator. As HotZ said in another post, changing out the part required that one be a bit of a contortionist. Small hands would be good also. Tie fishing line to your 7/32 socket and the rear screw so that you do not lose them. I almost lost the rear screw on the removal of the part. However all worked out and the climate control works as good as new. Thanks to HotZ28.
