Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-17-2010, 01:36 PM
MazdaX's Avatar
MazdaX MazdaX is offline
2001 Suburban Fuel Pump
So my fuel pump is toast in my suburban and I need to replace it. I found a OEM replacement for 100.00 online and ordered it after hearing a 1000+ quotes from all sorts of repair shops. Anywho , are there any tips or tricks to quickly removing the tank ? I have the walk through from the dealership but sometimes we all find our own short cuts =D
Oh and my starter and my water pump and my rear seal and my tail shaft seal and both sides tie rods haha..god this thing totally took a nose dive.
ADD : This is a 2WD - Single Tank - 1500.
2004 Mazda 6i
1997 Tahoe
Old 01-17-2010, 01:48 PM
danielsatur danielsatur is offline
Re: 2001 Suburban Fuel Pump
www.alldata.com, might have the trade secret for fuel pump removal.
New cars have an access panel behind seats, or in the trunk.
Old 01-17-2010, 02:57 PM
Cusser's Avatar
Cusser Cusser is offline
Mine's a 1994 Sub half-ton, 2WD, but my non-dealer mechanic (Arizona) just changed out the fuel pump on it for like $325 total, he used a genuine replacement fuel pump, not an off-brand. A thousand dollars is WAY too high, unbelievable.
Old 01-18-2010, 07:17 AM
mishalah's Avatar
mishalah mishalah is offline
Make sure your "oem" pump isn't from China. They have a life expectancy of about 300 miles from the complaints I read. You'd be just as well off with the Airtex.
Old 01-18-2010, 09:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Beware of the online 100 pump.
To cheap and may kit or may be after market off brand or imported look alike..
Go to your local parts place and tell them you want a Delphi OEM type pump.
Do not let them sell you a Airtex or off brand pump as they are junk.
Even if they have to order the Delphi pump.
MT
Old 01-18-2010, 11:29 AM
MazdaX's Avatar
It's an AC Delco / Delphi one. Airtex is crap so are the others. I've already done my research on it.
2004 Mazda 6i
1997 Tahoe
Old 01-18-2010, 01:41 PM
MT-2500's Avatar
AF - Advisor
You are smart there.
But only a 100$ for one is to good to be good.
Good Luck
MT
Old 01-19-2010, 06:44 AM
Cusser's Avatar
And labor can't be more than 3 hours, why I question the $1000 quotes.The fuel tank gets lowered a few inches for access.
At two different places, different years, an '88 Sub and a '94 Sub fuel pump replacements were $400 or less. With the '88 (higher price), shop also replaced the fuel pump relay on the firewall as a precaution. Each was 5.7 liter V8 2WD, older one was 31 gallon tank...neither fuel pump needed to be replaced again.
Old 01-20-2010, 02:02 AM
mishalah's Avatar
Would the 42 gal tank on my 4X4 make any difference in procedure?
Old 01-20-2010, 09:00 AM
MT-2500's Avatar
AF - Advisor
Fuel pump is mounted in top of tank.
MOST FUEL PUMP REPLACEMENTS REQUIRE THE TANK TO COME DOWN AND OFF.
MT
Old 01-20-2010, 11:57 AM
mishalah's Avatar
Been there, done that on my T&C van. I was just wondering if GM had a simpler way to do it. On my ZR-1 I can replace both pumps from the panel that holds the fill tube up on the top of the rear body. You'd think an access panel would be almost mandatory given the inherent dangers in removing the tank.
Old 01-20-2010, 01:39 PM
MT-2500's Avatar
AF - Advisor
T&C is not a suburban.
A suburban it is remove the fuel tank to replace the pump.
No danger in removing the tank if done right and the right equipement.
But how did your T&C /ZR-1 get 2 fuel pumps?
MT
Old 01-21-2010, 12:47 AM
MazdaX's Avatar
Also to solve your mystery fuel pump thing. 100.00 is my cost.retail is actually like 275.00. Anywho..I wanted any info on shortcuts to get the fuel tank off not info on bunk pumps. As I already said, i've done my research on pumps.
This tank is big , heavy and looks like a pain in the A to get out especially since its full to the brim with gasoline. Also this suburban is seemingly lower to the ground than other ones of same make / model i've seen.I had to lift the body with a fork lift and put 3 pallets under each of the front wheels just to be able to get to the starter.
I don't have a tranny jack at my disposel but I have a super nice fork lift =D Also are the hose clamps on the 2001 models for the fuel pump module the quick connect style or are they the typical ring clamp ? I'm not too concerner about breaking the elbows for the shot fuel pump but i'd prefer not to screw up the hoses.
On another note - I had an alignment done before crap hit the fan and it was all groovy but it suddenly got insanle hard to steer to the right @ random times and perfectly normal for straight and left hand turns. WTf is wrong with this thing ?
2004 Mazda 6i
1997 Tahoe
Old 01-21-2010, 02:42 AM
mishalah's Avatar
The T&C van has only one fuel pump, but it also requires dropping the entire tank to get at it and the sending unit. I'd guess it's similar to dropping the Suburban tank.
The ZR-1 has two pumps because it has two sets of injectors. The primary pump is always on and feeds the first 8 injectors while the second pump kicks in with the second set (normally around 3000 rpms). That's because the LT5 engine requires a lot of fuel and air at WOT and one pump just doesn't cut it. It's interesting that GM (actually Mercury Marine/Lotus) felt the big block Suburban pump was best for pushing all that fuel at 7000+ rpms. Apparently, they had a lot of confidence in the Delco pumps. At least they had the sense to make them accessible if one or the other failed.
Old 01-21-2010, 02:45 AM
mishalah's Avatar
I'd check your tires for a slipped belt or separation. Far too many tires are also coming in from China and are not the same quality as we were used to.
