Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-10-2010, 05:18 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
ABS failure
I'm having a problem with my ABS as of yesterday. The code is C1236 - Left Rear Wheel Speed Sensor Information Missing.
Would a failed speed sensor cause this? And if so, how hard of a job is it? I figure wheel will have to come off, but will I have to take the rotor off, too?
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 01-10-2010, 07:11 PM
old_master's Avatar
Advisor/Moderator
Re: ABS failure
The DTC is telling you the EBCM is not recieving a signal from the left rear wheel. There are several things that can cause that. Poor connection, broken wire, faulty EBCM, air gap too large, or a faulty wheel speed sensor to name a few. An ABS capable scan tool, a DVOM and a shop manual will be necessary to diagnose exactly what the problem is, without throwing parts needlessly at it.
You have to know how it works,
to figure out why it doesn't.
Old 01-10-2010, 07:51 PM
danielsatur danielsatur is offline
Re: ABS failure
Try cleaning the wheel sensor ,and tooth ring with brake dust cleaner.
Old 01-11-2010, 01:59 PM
Re: ABS failure
I will for sure try cleaning, but my concern is that according to the code, it's indicating that the module is receiving no information from the sensor and not just invalid information.
Oh, and for what it's worth I did the J-mod the day before this started occurring. But I drove it that night and had no issues with it even in the heavy snow conditions. Traction control and ABS were both working fine.
Old 01-11-2010, 02:06 PM
Re: ABS failure
If the sensor is bad, there's a graveyard of parts for this type of car.
Old 01-11-2010, 04:56 PM
Re: ABS failure
Very true, but I read that the bolt holding this sensor in may be pretty badly rusted and usually breaks since I live in the rust belt.
Old 01-16-2010, 03:03 PM
Re: ABS failure
Just checked the codes again and now there's two codes relating to this.
In addition to the C1236 as I mentioned above, it's giving me a C1175 - Left Rear Speed Sensor Input Circuit Failure
Would a failed sensor throw that code, or would it explicitly be a short/open circuit?
Old 01-16-2010, 05:01 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: ABS failure
You can change the sensor without rotor removal. Use the good ol' penetranting oil loosening up thing to aid in bolt removal. You may have to twist the sensor to get it out. Both codes will probably be cured with sensor replacement.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-16-2010, 05:42 PM
Re: ABS failure
Thanks way2old. I was hoping you'd chime in on this one! I'll let you know how replacement goes and if it fixes the issue.
Old 01-16-2010, 08:07 PM
way2old's Avatar
TOKEN HILLBILLY
Re: ABS failure
Hey Blue. I have been reading your replies and don't have to answer as much any more. You are doing a good job in your replies. Nice to see you taking such an interest in site..
Old 01-16-2010, 11:29 PM
Re: ABS failure
Thanks, I enjoy helping as much as I enjoy learning. Just passing on what I can to others
