Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-08-2010, 06:27 PM
VividVisions VividVisions is offline
p0300 code
;03 tahoe, 5.3
ok, here we go
pull the dipstick, looks milky and high level, smells like gas, replaced fuel presure regulator, changed oil, still same result.
pulled all spark plugs, number 4 and six looked awful clean,
pulled dipstick while running, smoke coming out like a steam machine.
can't rev past 2500 rpm
someone help, i'm about to pull my hair out.
Old 01-08-2010, 06:41 PM
danielsatur danielsatur is offline
Re: p0300 code
Trouble with Intake or head gaskets, see http://www.automotiveforums.com/vbul...d.php?t=974539
Old 01-08-2010, 06:52 PM
Re: p0300 code
ok, my buddy come over and said i am crazy and the oil isn't milky, pulled 4 and 6 plugs and they got color now, sprayed brake cleaner around intake, no idle change, the idle is rough but i figured it woulda killed it or reved up but nothing. i'm thinkin sensors now, maybe an o2
Old 01-08-2010, 07:08 PM
Re: p0300 code
Is the coolant aux tank contaminated with oil?
Doe's it smell like oil or gas?
Old 01-08-2010, 07:17 PM
Re: p0300 code
prime fuel pressure 52psi then dies down to 49, while running pulled passenger side wires, no difference, go to the driver side and it dies, gotta be fuel pump?? or should i try and bypass that fancy unit that it goes into right after the tank?
Old 01-08-2010, 07:23 PM
Re: p0300 code
coolant is fine, and the oil i drained out the first time smells like gas, but i believe that is from the pressure regulator cuz when i took it off and sucked on it to see if it was working i got a mouthful of gas, running fuel pressure is about 47psi, passenger side cat is cool compared to driverside,
Old 01-08-2010, 07:27 PM
Re: p0300 code
I have seen a plugged cat on one bank, causing muti misfires!
see http://www.automotiveforums.com/vbul...d.php?t=972629
Old 01-08-2010, 07:30 PM
Re: p0300 code
something is just really weird, it smells like its running rich, and when i pulled the wires there is spark in between the coil and wire, they are brand new wires and plugs
