Old 12-01-2009, 10:10 AM
blazi99c blazi99c is offline
Service 4wd 99 blazer
Hello
My brother push my car Without runs engine whit gear N. SERVICE 4WD light come on.
Now i have 4hi, if I want change to 2hi, I press Switch 2hi He blinks Nothing happens, Some switch only can be heard not mechanicall only electricall.
Please help.
Old 12-01-2009, 10:15 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Service 4wd 99 blazer
Originally Posted by blazi99c View Post
Hello
Please help.
How far was the push?
Have you tryed a reset on it by pulling 4W fuse?
Have you tryed putting transmissionin neutral or backing up and rooling forward a little?
What transfer case does it have
MT
Old 12-01-2009, 04:46 PM
1. he say 2meters
2. yes Nothing happens
3. It will try today
4.np 236
Old 12-01-2009, 05:22 PM
MT-2500's Avatar
AF - Advisor
1. he say 2meters
4.np 236
Have you tryed to reset it by pulling fuse?
The 236 transfer case can be tested and checked out and code read out with a engine/transmission/transfer case capable scanner.
Post back any codes you get.
Let us know how it goes.
MT
Old 12-01-2009, 05:32 PM
MT-2500's Avatar
AF - Advisor
How many miles on it?
Has transfer case ever been serviced?
MT
Old 12-01-2009, 05:42 PM
yes i pulling fuse and Nothing happens
As I can check it 236 ?
Today i go to garage , I unhave Tech2 scaner.
Only normal OBD-II with ScanXL™ Professional + GM
Old 12-01-2009, 05:48 PM
i have 175000 km
I have bought my car 1 year ago and I unknow if anybody or somebody served him.
PS i living in Poland And I unknow specialists from this service of type of equipment here.
Old 12-01-2009, 06:10 PM
MT-2500's Avatar
AF - Advisor
i have 175000 km
Not much you can do without the transfer capable scanner.
Check around for a repair shop that has one.
Good Luck
MT
Old 12-01-2009, 06:24 PM
MT-2500's Avatar
AF - Advisor
If no capable scanner can be found.
Always check all fuses and wiring.
A factory repair manual or a All Data online sub has a lot of circuit and voltage checks and switch test you can run on switch and transfer case control module and encoder motor and a pin out voltage check on module.
http://www.alldata.com/products/diy/index.html
Good Luck and let us know how it goes.
MT
Old 12-02-2009, 06:29 AM
code i get c0323 and c0387 .
I have disconnected all wires and there is Clean with special spray.
I connected back and get code c0323 and c0310.
Old 12-02-2009, 08:46 AM
MT-2500's Avatar
AF - Advisor
Good find on the codes.
There is you problem.
Did you get them with a OBD11 scanner or a transfer case scanner?
323 is a code for transfer case lock solenoid circuit.
387 is no shift code.
Code 310 is a shift motor circuit open or bad shift motor.
323 and 310 are both circuit problems.
Make sure you check all wiring and power feeds and grounds.
Get the repair flow chart for them codes and go threw the repair flow charts.
Check all wiring circuits and power feeds and do not forget grounds.
Factory repair manual or a A -All Data online sub will have the repair flow charts and take you threw the repair.
Good luck
MT
Old 12-05-2009, 11:02 AM
I have given other shift motor and its ok.
It thanks for interest my problem
Old 12-05-2009, 11:09 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went and the fix.
Good Luck
MT
