Old 11-23-2009, 06:09 PM
Guillot Guillot is offline
Angry Need help with a 2002 chevy silverado.4.3 random cylinder misfire
ok i have a 2002 chevy silverado with a 4.3 in it. I got a code for a bad cam and crank senor. So i replaced them and now the check engine light is still on so i took it to get it checked out and now they tell me that i have a random cylinder misfire now. So i go and replace spark plugs,wires,cap and button. Well its still skipping it does it when i push the gas a little or when i am at a taking off from a red light or riding down the hwy steady it skips bad. Now does anybody know anything about this problem?
Thanks
Mike
Old 11-23-2009, 08:43 PM
danielsatur danielsatur is offline
Re: Need help with a 2002 chevy silverado.4.3 random cylinder misfire
I would start with a MAF sensor, up-stream 02 sensors, and a good throttle body cleaning.
Is there any DTC's?
Old 11-23-2009, 08:49 PM
j cAT j cAT is offline
Originally Posted by Guillot View Post
ok i have a 2002 chevy silverado with a 4.3 in it. I got a code for a bad cam and crank senor. So i replaced them and now the check engine light is still on so i took it to get it checked out and now they tell me that i have a random cylinder misfire now. So i go and replace spark plugs,wires,cap and button. Well its still skipping it does it when i push the gas a little or when i am at a taking off from a red light or riding down the hwy steady it skips bad. Now does anybody know anything about this problem? oh yea it has 125000 on it
Thanks
Mike
step 1: measure fuel pressure...random miss fire is usually the fuel pressure...
So what eactly is the DTC'S pulled ? this would be more helpful...
a bad crank/cam sensor. what DTC'S were pulled with that issue ?
Old 11-23-2009, 09:22 PM
Is there any DTC's?
MAF is new all so sorry i have cleaned the throttle body.
Old 11-23-2009, 09:27 PM
Ok i new i was going to get asked this.lol sorry the first time that i got the code i did not get the # they just told me that i needed a crank/cam sensor and that was it. Then check engine light went off. Then 4 hours later it comes back on and runs rough and some times it will go off and stay off fort about a 1hr or 2 and then come back on and stay on for days or sometimes 1 day and goes back off but it pulls a P0300 code every time?
Old 11-23-2009, 09:56 PM
Are you sure it's random misfires, I did a ''In the car Injector service'' , some clown had extra injector seals forced into the fuel rails.
Is your Throttle body a drive-by-wire system?
Old 11-23-2009, 09:59 PM
yea i am sure thats what the computer said i have had the truck for about 6 weeks and it has just started doing it.
What do you mean bye is my Throttle body a drive-by-wire system?
Old 11-23-2009, 10:16 PM
The drive-by-wire system, the accelerator pedal is electronic control, not cable driven.
The throttle body has a electronic control for the throttle plate, it can get stickey and cause random misfires.
Old 11-23-2009, 10:20 PM
The drive-by-wire system, the accelerator pedal is a electronic control, not cable driven.
The throttle body has a electronic control for the throttle plate.
oh sorry yea it is the drive-by-wire system it does have a cable
Old 11-23-2009, 10:29 PM
Actually, I have seen cable driven throttle bodies lost hp, because of a stickey throttle plate.
http://www.automotiveforums.com/vbul...d.php?t=949299
Poor emissions during two drive cycles!
125k miles on this truck, you did the plugs, MAF, and throttle body cleaning.
Opps!
What about the up-stream 02 sensors?
Old 11-23-2009, 10:38 PM
I will check that out but i just dont think that is it. But you never know i have tried almost everything else.
Old 11-24-2009, 07:41 AM
fuel pressure fuel, pressure fuel , pressure fuel pressure, and fuel pressure..............step 1....
It is your vehicle though so if you like to spend some money with no results go for it.
Old 11-24-2009, 08:04 AM
thats what some one else has said that it might be the spider injectors on my truck?
Old 11-24-2009, 06:55 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Did you do a cam/crank sync after you put it the new sensors?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-24-2009, 08:11 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
This is what I would check (in this order)
Coil, rotor, vacuum leak between the MAF and TB, compression test.
Dragging people kicking and screaming into the enlightenment.
