Old 11-18-2009, 05:22 PM
hoffman88 hoffman88 is offline
A/C Compressor Plate loose. Washer is raddling.
A/C Compressor Plate loose. Washer is raddling. can i tighten this some how without having to replace the whole unit?
Old 11-18-2009, 06:58 PM
Torch Torch is offline
Re: A/C Compressor Plate loose. Washer is raddling.
Year and model?
Old 11-18-2009, 06:59 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
If you can find the right size bolt for it. It is a bolt that bolts into the compressor shaft. If the bolt is there, tighten it down and you should be OK.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-30-2009, 02:21 PM
F150 2001, Rattle goes away when the Heater or AC is on... However, the truck gives a Loud Tick, then the rattle comes then a another tick and the rattle stops.... it continues to repeat this process as long as the heat or ac is on. Heater does blow hot air still.
Old 12-04-2009, 01:31 AM
walldogg03 walldogg03 is offline
i would recommend that you put loctite on the treads of the clutch plate bolt when you go to tighten the bolt down, i would inspect also if any damage has been done to the mating surface if you say the washer has been rattling around, but i agree that if you tighten it you should be fine
