Go Back   Automotive Forums .com Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 11-18-2009, 03:21 PM   #1
bluebug
bluebug's Avatar
1974 Ghia Transmission
I have a 74 Ghia that I want to put an 5speed overdrive transmission into. What would be a good substitute?
The car is all original right now, down to the 13 inch wheels.
It has been garaged for the last 20 years.
I am thinking of getting it out for a daily driver and want to increase its fuel economy.
Thanks
bluebug is offline   Reply With Quote
Old 11-19-2009, 09:16 AM   #2
MrPbody
AF -Advisor
Re: 1974 Ghia Transmission
Which engine? 4 or 6?
Jim
MrPbody is offline   Reply With Quote
Old 11-19-2009, 02:34 PM   #3
bluebug
bluebug's Avatar
2300 4 cylinder.
Clark
Old 11-24-2009, 12:48 PM   #4
MrPbody
AF -Advisor
Clark,
Sorry for the delay...
I'm thinking the 5-speed from an early '90s Ranger would "bolt up". The 2.3 block is still pretty much the same. Some checking of the clutch splines, overall length and shifter location would be in order. Perhaps there's a local wrecking yard with such a pickup there. I'm sure they would allow you to take measurements, especially if you intended to buy the trans IF it "fits".
You may need the bellhousing, flywheel, etc. The same wrecking yard should have an "interchange" manual, that should have that info.
You could also contact Kiesler (trans people).
Jim
