Old 11-18-2009, 09:11 AM
charlie40 charlie40 is offline
06 f-150 4x4
the 4x4 will not work no light on dash . checked all fuses and relays. no power at trans case motor. changed dash switch still no 4x4. can any one help with this issue.THANKS.
Old 11-18-2009, 08:39 PM
dfordski's Avatar
dfordski dfordski is offline
Re: 06 f-150 4x4
Are you trying to say "My truck will not go into 4wd, and also the corresponding light does not come on?"
"Saving the World......One Ford Truck at a Time!"
Old 11-19-2009, 06:59 AM
Re: 06 f-150 4x4
yes sorry i have no 4x4 it does not ingage the t-case or axle.
Old 11-19-2009, 10:42 PM
dfordski's Avatar
Re: 06 f-150 4x4
Never had a 4wd, however it sounds like you should check for power at the switch w/key on, If it normally came on w/ key on. If there is no power there,and all fuses are intact, then I wood suspect a blown fuseable link under the hood. Also, an error code scan should cough up an error code re: transmission system function errors which will be #'s prefixed P07xx thru P09xx and P17xx thru P19xx.
Old 11-20-2009, 11:54 AM
Re: 06 f-150 4x4
Thanks ill look for a link that might be blown. i scaned the truck but only get an 02 sensor code.
Old 11-21-2009, 01:29 PM
dfordski's Avatar
Re: 06 f-150 4x4
Thanks ill look for a link that might be blown. I scanned the truck but only get an 02 sensor code.
It would probaly be one of the heavy gauge wires coming off the always hot starter solenoid post connection. At the switch, w/ power on, you should show power to ground, on one wire, and continuity to ground, on the other one. this should tell you which direction to pursue. Unless the ground path goes thru a selinoid, in which case that would act as an open switch and would not show continuity. Your wiring diagram would tell you what your dealing with & if it is in fact a 12v circuit. In which case you could could wire the switch temporarily off the battery to see if the circuit energizes. Anything else malfunctioning, like the speedo? Something that might include circuit safty interupts?
Old 11-26-2009, 12:33 PM
Re: 06 f-150 4x4
it was the motor on the transfer case. thanks for all the replys.
Old 12-08-2009, 09:11 PM
sandman65 sandman65 is offline
Re: 06 f-150 4x4
Replace the solenoid that is on the firewall behind the battery...that is a good place to start, it controls the vacuum that engages/disengages the hubs. There is an updated version, be sure the vacuum hoses are installed fully, I used dilectric grease in the electrical connection. This thing is fussy and cannot handle any moisture. Good luck.
