Old 11-06-2009, 05:30 PM
JShawnA JShawnA is offline
93 Metro Low Compression doesn't raise when oil put in cylinders
I have a 93 Metro 1.0 3cyl, it is hard to start, and doesn't idle well. Once it gets running it drives great when the RPMs are up. Today I got it warmed up and checked the compression.
#1 - 45
#2 - 110
#3 - 40
I then put about a teaspoon of oil into each cylinder and rechecked.
#1 - 50
#2 - 120
#3 - 45
Each cylinder didn't go up by much. Am I correct in thinking I may have a bad camshaft?
Old 11-06-2009, 06:51 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 93 Metro Low Compression doesn't raise when oil put in cylinders
you have 2 burned exhaust valves. head needs to be rebuilt or replaced and should do the rings at the same time
Old 11-06-2009, 06:59 PM
Thanks for the reply. I'm guessing that must be a common problem on these engines? I have quite a few years of wrenching experience, but this is the 1st Metro I have owned. My 1st guess was worn camshaft lobes, but I could definitely see burned valves causing the same symptoms.
Old 11-06-2009, 07:01 PM
Crvett69's Avatar
never seen a cam lobe on a metro wear this far but seen lots of them burn valves
Old 11-06-2009, 07:06 PM
Cool. I'll start tearing into it tomorrow. I'm debating buying a $500 JDM motor, or buying a complete rebuilt head for $200 and doing the rings/bearings myself.
Old 11-06-2009, 08:57 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
These engines are easy to rebuild. I been a mechanic for years, but never did any kind of rebuilds until I got my Metro. Here are some helpful topics with pictures to help on your quest...........
1.0L Head Repair Guide
Detailed 1.0L Head Rebuild
Extreme Metro Makeover
Bottom End Rebuild
The Weekend Rebuild
You can also find more info here............. Indexus Metrogloditus
Good Luck!
