Old 10-27-2009, 12:06 PM
all power all power is offline
v8 in a 00 gtp ??????
read this in a hod rod book a man took a 4.8 or a 5.3 and put it in his 2000 gtp and the only thing he said he had to change was headers for the back and the trans from his 3.8 bolted right up because its the same block just a diff bore. the pcm he got out of the gxp were he got the motor and said it runs like a gto......... is this bull crap or can it be done that easy????????
Old 10-27-2009, 12:41 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Re: v8 in a 00 gtp ??????
If it can be done that easy, sign me up!
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 10-27-2009, 08:49 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
its not bull. not sure about the 4T65E-HD bolting right up to the motor. i did see a 98 GTP on Ebay a while back with the N* V8 in there. car looked like a real piece though.
Old 10-28-2009, 12:31 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Yeah, I remember that ebay one. That guy had a reserve of 10,000 or so and no one was bidding on it. No one wanted the junkstar. Can you tell I am not a fan of the N* motor? Why someone would want that in their GTP instead of the 3800SC is beyond me. N*'s have virtually no aftermarket, not to mention for the size of the displacement, you would think it should get more HP. Anyone ever change the starter in a N* motor?
Not sure if the 5.3 from a GXP would bolt in or not, but bolting straight up to the 4T65e-HD sounds a little far fetched. The 5.3 would need its own computer, and I doubt the computer wouldbe able to controll the 4t65e-hd..... But I suppose it is possible. If so, I'd like to see it. And I too would be interested..... (if only I had a garage stall I could use for a few months).
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-28-2009, 06:42 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Just get a '05-'08 GXP and problem solved.
Timeslip 08/12/06
AF Community Guidelines
Old 10-28-2009, 09:58 AM
00GTP4ME's Avatar
I actually like the body style of the 97-03's better than the 04+'s. They're not bad, but I was a little disappointed when they came out. They look too much like bonnevilles to me.
Old 10-28-2009, 07:03 PM
CrazyHorst CrazyHorst is offline
First the 3800 and the 5.3L engines do not share the same block. Very different animules. Although the 5.3L differs from the classic Chevy 350 small block by having a deep-skirt block (original 350 is split at the crank centerline). The S2 3800 has always had the deep skirt cross-bolted mains hence the bulletproof lower end easily adapted to the additional stresses of power charging.
I doo agree with Bnaylor that your money is best spent getting a GXP....and should you choose...transplant the entire front cradle into the original recipe GTP (no guarantees this is a bolt-on fit, either). The next 3-4 years would be consumed straightening out the electronics.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 10-28-2009, 08:52 PM
1typhoon 1typhoon is offline
Banned
I have, it's one of the easiest to change. Takes about an hour and you don't have to crawl under the car. Most people have to never change one, they last a looooong time.
Old 10-28-2009, 11:30 PM
tblake's Avatar
In God We Trust
1 hour? For real? You must be one quick mechanic (cleaning up all them LIM Gasket surfaces). Although I dont think it would take me an hour to install one on my GTP.
And Bob, someday I will have my 08 GXP, Black, Black leather interior....
Old 10-29-2009, 10:00 PM
me too
I've been keeping my eyes peeled. i either want a black one, or that dark blue/green. i LOVE that color
Old 10-29-2009, 10:37 PM
wafrederick wafrederick is offline
Banned
The 350 and 5.3 have a differant bolt pattern for the bell housing.The Northstar is acually not a good engine and I know one yard that sells them left and right.The Northstar is known for head gaskets blowing and a special heli coil set made by Kent Moore has to be used to inset heli coils for the headbolt threads.The threads strip out when the headgaskets fail since the block is aluminum and the threads go down to the main caps.I have heard the 2001 and up Northstars are horrible to change,My father turned one down after reading on one to change the engine since it has to come out from the bottom.
Old 10-30-2009, 09:25 AM
tblake's Avatar
In God We Trust
Originally Posted by grandprixgtx00 View Post
me too
......or that dark blue/green. i LOVE that color
Me Too!
Old 10-30-2009, 09:31 AM
tblake's Avatar
In God We Trust
Really? I have heard about head gasket failures, but never the head bolts stripping. What a piece of junk! You would think that having to use a heli-coil on head bolts would cause premature failure of the new gaskets. So pretty much if you blow one head gasket, you might as well buy a new block or else you will ocntinue to blow head gaskets? Gosh, the more I hear about that motor, the more I hate it. Good thing its mainly old people with deep pocketbooks who drive caddy's!
Old 10-30-2009, 06:16 PM
Banned
The headbolt threads pull out when the headgaskets go,even removing the headbolts and you will have a hard time torqueing the headbolts down if the heli coils are not installed,the threads will strip out.Although Cadillac is part of GM,there is Cadillac and there is GM which are not the same.Cadillac does it their way and GM cannot do it anything about it
Old 11-04-2009, 07:53 PM
BNaylor's Avatar
What have you been smoking? ....
The different front and rear clips on the GXP makes the difference. BTW - You wouldn't catch me driving a Bonny.
Timeslip 08/12/06
