1989 2.8 not running right
I have a 1989 Grand Prix with a 2.8L.It recently quit on me while accelerating out of a parking lot into traffic.Now it won't stay running.Has new fuel pump,TPS,plugs and wires,is getting spark,checked the IAC,MAP,ECM,EGR,CPS all is good.It gives a MAP code but I tried a different MAP to no avail.It will turn over and start but runs like it is on 2 cylinders and as soon as you give it gas it quits.I am pointing toward timing issue
Re: 1989 2.8 not running right
Welcome to AF.
Instead of posting a link to another forum where you have an issue posted make a new post here (copy and paste) or someone might construe your post as violating the rules.
ok..editted first post...any thoughts??
Double check your fuel pressure. Just because a part is new, doesn't mean it couldn't/didn't fail.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Is it getting spark on all cylinders? You could yank the ICM off there and bring it in for testing.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
did that..everything checked good
I hear ya....I do not have a pressure gauge to do that..the first thing I did with this problem is change the fuel pump that only had 10,000 miles and I thought it had failed..figured what are the odds 2 pumps are bad. I know I should still check that though |
it was a bad fuel injector
