Old 10-03-2009, 05:12 AM
lance_kidd lance_kidd is offline
Check Coolant Light
I have a 01 Pontiac Grand Prix. About four or five months ago the Pontiac Dealership, which has since closed down, replaced the intake manifold gaskets and hoses and whatever the hell it was cost me $900 cause it was leaking coolant, which is a common problem for this model.
But anyways, about four months ago the coolant light come on and won't go off. I've kept an eye on it since then and the coolant isn't leaking or low at all. Is there a simple way to get the light off and is this something that the dealership could have done (I don't see how but want to make sure) and might repair for free if it is there fault.
The light wasn't on when they fixed the problem but it come on after about two weeks and hasn't went off since.
Old 10-03-2009, 10:33 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Check Coolant Light
That sensor is located in the side tank of the radiator. It will look like this
You can try tapping it with the handle of a screwdriver lightly to see if there is an air pocket stuck in it. Also make sure the radiator is full and not just the overflow.
Old 10-03-2009, 11:11 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Yeah there is an easy way to get it to shut off..... unplug it.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-04-2009, 02:41 AM
I haven't had the chance to tap it with a screwdriver yet, but if I can't get it off:
1. Is it easy to unplug?
2. Is it something I can replace on my own with removing the radiator since it's inside of it?
Thanks
Old 10-04-2009, 07:43 AM
valente valente is offline
I think Airjer said "on the side"not inside the radiator
Old 10-04-2009, 01:35 PM
Airjer_'s Avatar
Its easy to unplug and its easy to remove. It is on the outside of the radiator.
Old 10-07-2009, 12:43 AM
Tried the screwdriver tap but it didn't work. The radiator was full to the top, so since the intake gaskets have been replaced, I'm not concerned about it leaking, so I unplugged it.
Thanks for the help with that. If I decided to replaced that thing one day, any idea on how much it cost? It shouldn't be that hard to put a new one on.
Thanks again,
Chris
Old 10-07-2009, 09:37 AM
Airjer_'s Avatar
$60 ruffly
Old 10-07-2009, 06:00 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
I replaced mine a year or two ago. $60 sounds right. Probably took 15 minutes or so. The only tool I used was needle-nose pliars for the spring retainer. It's a little tight, but not bad.
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 10-08-2009, 02:35 AM
doctorhrdware doctorhrdware is offline
If want to make it easier to get to the sensor, just remove the battery.
Old 10-11-2009, 12:22 PM
Marnav1 Marnav1 is offline
Can't you just pop out the headlight assy?
Old 10-11-2009, 01:36 PM
I did not check that out, but it is worth a shot to try it.
Old 10-12-2009, 02:23 PM
Brent S Brent S is offline
I was successful in cleaning the typical brown sludge out of my coolant sensor, by bending a wire hanger in just the right way, and poking it around (into the sensor) through the radiator filler neck. If you can knock the sludge off the little electrode, it should work again. This way, you don't even have to drain coolant.
Tags
coolant , light , low
