Old 04-06-2003, 09:42 PM
blade34609's Avatar
blade34609 blade34609 is offline
Seat Belts in my Civic!
Hi,
I just bought a 1990 Honda Civic LX 4 door and I have a problem with the seat belt indicator light. It keeps beeping and flashing over and over even with both seat belts locked in.
I need to know a way to somehow disable that indicator light. Do you know if there is a fuse box or wire to disconnect untill I could figure out the problem. The sounds and flashing light really make driving it very annoying.
Thanks,
Owen
Old 04-06-2003, 10:00 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
Honda seat beltsare covered under life time warranty, take it to a dealer and have the check it out, just ask if its warranty first....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 04-06-2003, 10:05 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Just remove the bulb from the gauge cluster.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 04-06-2003, 10:21 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
are the seatbelts not working? If one or both aren't working, check the fuses on the positive post of the battery, those fuses are for the automatic seatbelts
Empty Pockets Racing Member #1
Old 04-07-2003, 10:00 AM
el_loco_civic's Avatar
el_loco_civic el_loco_civic is offline
Send a message via Yahoo to el_loco_civic
Heres what it MIGHT be.
If you unbolt your seats, there is a plug connected to the bottom of the seat, the ones that go to your dash and make the little light blink and all that. It might be unplugged or cut off or maybe even ripped off. So just unbolt , or maybe u can just stick your hand under the back of the seat to try and see if they are plugged in together. Hope this helps !
Civic - Trashed it
Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree..
New Plans : Teggy / or / Tiburon
Old 04-07-2003, 11:34 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
nonononono, it may not even have anything to do with the seatbelt. remember that on this car the seatbelt light also functions as an old school warning light. kinda like a check engine light for the rest of your car. if you have no taillights, or something along those lines, the light will blink on and off and make lots of noise. check all of your fuses and all of your lightbulbs before you start messing with the seatbelt sensors. its just like when you leave your hatch slightly open, or either door, and the door light makes noise and comes on.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-07-2003, 01:43 PM
might be, i got same car, and thats just what happened w/me. I took everything except front dash out of my car , carpet, seats, door panels.. everything,, with the front seats out, theres the lil wires that connected to it, but they werent connected no more, and thats the only thing that ever made my seat belt thing flash.. even if my motor was draggin on the road
Civic - Trashed it
Old 04-07-2003, 01:49 PM
blade34609's Avatar
Gauge Removal
Hi,
Is it possible like someone suggested to just remove my gauge cluster and take out the bulb to the seatbelt?
I know it would stop the blinking but would ut stop the beeping?
Thanks,
owen
Old 04-07-2003, 06:09 PM
EF You's Avatar
EF Life Giver
if you have checked the seatbelt plugs, and it still doesnt stop making the noise and flashing, then you seriously needa check your brake light fuse. its the yellow fuse in the engine bay fuse box. trust me, cause i got my car with a uhaul tow package already on it, and the idiots hooked up the trailer wires very poorly, and occasionally they would ground out the brake lights and blow the fuse, then it would start beeping and the seatbelt light would flash. theres reasons behind all the flashing stuff on your dashboard other than annoying you. its there to annoy you into checking the things that went wrong. i wouldnt just unplug shit like a redneck whenever things start making noise
99' Ram Quad Cab -I Need Seat belt Help PLEASE!! nrosssr Ram Pickup | Ram SRT10 0 03-30-2009 05:42 PM
2002 Civic seat belt pillar alto2 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 03-06-2004 02:53 PM
Seat Belt problem in Civic! blade34609 Engineering/ Technical 1 04-07-2003 01:18 AM
seat belt beeper on 91 civic uplandht '88 - '91 Civic | CRX | Wagon | Shuttlee 6 09-02-2002 10:49 AM
