Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 09-28-2009, 01:13 PM
geraldl geraldl is offline
Question How to get into ECM Diagnostics mode
Hi all, I need to read the error codes out of my 2001 Sentra 1.8L GXE. I am sure I have done this before and don't think I could use the one with pressing the accelerator cause I believe this model as a throttle cable. Thanks
Old 10-01-2009, 07:31 PM
stamar stamar is offline
Re: How to get into ECM Diagnostics mode
all cars after 1996 require a obd 2 diagnostic tool
97 sentra gxe auto 174k miles
89 nissan d21 truck z24i 213k miles ( with a cabover camper)
Old 10-05-2009, 04:50 PM
Not all cars Stamar. 2003 Chrysler's, turn the key on three times and it gives you your P### right on the trip display. 2003 sentra with a throttle switch have a procedure to count the flashes of the service light.
Old 10-12-2009, 02:57 PM
if so I stand corrected
I once had a dodge van ( biggest peice of crap ever but that might be another story)
1994, and it did have obd 1, and the chrysler method is usually to turn the key three times
however Im positive that 1996 dodge vans have no such thing
If they brought it back that is peculiar but its true I havent owned a 2000 or newer car
ok so the next thing you are describing 2003 sentras have a flash mode as well?
No idea but i doubt that because I own both a 89 ( obd 1) nissan truck and owned a 91 infiniti g20 and they did not have a flash mode per say
older nissans kept the ecm between the two seats in the front of the cab. To flash the codes you turned the disk with a screwdriver and the ecm itself flash the codes.
obd 1 nissans ( which again is not yours) needed some propierty nissan tool to read the full codes.
Old 10-15-2009, 09:56 PM
Thumbs up Re: How to get into ECM Diagnostics mode
I had two 2003 Chrysler's here, an SX 2.0 and PT Cruiser. It is something sweet, not counting flashes, but an actually P number on the screen. I guess they needed it cause I had to check them often. As for the Nissan, my light is off now and no more issues. The only other time this happened was due to a bad seal around the gas cap. Models after mine with the throttle switch have a sequence pumping the accelerator pedal , some ppl with throttle cable tried and flooded their engine. Gotta love the reliability of the Japanese cars.
Old 10-16-2009, 09:13 AM
definitely japanese is the way to go for me
I ended up getting so many nissans because they are cheaper on the used market than hondas or toyotas
so for used cars thats the way to go. Both my cars right now have near 200k miles and an american or european car that has 200k miles and is bullet proof just isnt out there.
Ive had 4 nissans mostly because of the used car market. They are also usually one of the easiest brands to work with.
