Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 09-28-2009, 12:38 AM
96DEVILLE 96DEVILLE is offline
98 deville wont start
i have a 98 deville ,it turns over but want start. i getting fuel to rail on motor .power to the injecters, spark to plugs..i changed coils & pcm from another 98deville and still no start. this happened like this.... i drove to the store one day came out and car would not start. dead no power no lights no anything i got a jump from AAA drove car home removed battery charged it put it back and car just wouldn t start..it turned over but not start i checked fuses changed batterys ...nothing works PLEASE HELP
Old 09-28-2009, 12:06 PM
maxwedge maxwedge is offline
A990 racer
Re: 98 deville wont start
Do the injec tors pulse when cranked, is the fuel pressure the proper pressure, will it start spraying carb cleaner into the intake?
Old 09-29-2009, 01:39 AM
i tried spraying quick start and it does nothing no atempt to start, i dont no fuel pressure, but it shoots out the end of fuel rail if i hold i valve and crank motor.. and i only know i am getting power to the injecters by checking power in the wires going to injec.... thanks
Old 09-29-2009, 03:26 PM
A990 racer
If it won't start with carb cleaner you have no or weak/no spark, if the compression and timing are ok.
Old 09-29-2009, 03:47 PM
i don t know, i can t check that myself.... thank you...this car also has a remote starter does yhat have any thing to do with it......do northstar have a timeing chane...
Old 09-29-2009, 06:23 PM
A990 racer
Remote start operates the ign and starter, could be something there, the N'star has a chain, not normally an issue.
Old 09-30-2009, 04:13 AM
remote start operates the ign and starter, could be something there, the n'star has a chain, not normally an issue.
well thanks again... Iwill have to wait till weekend and try to get running again... You gave me some good info... I ll let you know if i get it running.........thanks again for your help...peace
