Old 09-19-2009, 09:40 PM
SHAMILL SHAMILL is offline
water pump replacement
I have a 2003 Chevy Silverado 2500 HD 4WD 6.0L V8 with A/C. I need to replace the water pump. Does anyone know which make of water pump is comparable to the origional part. I only want to have to do this once. I want a part that is going to last.
Old 09-19-2009, 10:45 PM
jyount jyount is offline
Re: water pump replacement
The dealers around here will give a comparable price on most parts. Nothing quite like oem usually. But I trust napa for most parts, I don't like the box stores are all, napa is trying to become one I know, but they aren't yet. The carquests around here has good parts too.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 09-20-2009, 09:38 AM
j cAT j cAT is offline
buy a new[not rebuilt] water pump from GM..my water pump is still good 2000 silverado...
water pumps fail when the coolant is defective,,fan out of balance/bent..or the fan clutch is n/g..
usually these water pump leaks are actually the gasket of the water pump...engine mount,,,metal gets corroded..
Old 09-20-2009, 01:05 PM
wafrederick wafrederick is offline
Banned
You can get new waterpumps from Carquest too,a little bit more than a rebuilt and it is an option.I will never step in a Napa parts store,sponsorship is on a Toyota race car driven by Micheal Waltrip and I boycott that.Plus their parts are very expensive and they do sell some junk parts.Their alternators and starters are this way.My father bought a Chevy truck with a bad starter,was a new Napa starter.Avoid using the special fan blade wrenches,break real easy due to being too thin and are a huge waste of money.I use an air hammer with a long bit to remove the fan blade which is a quicker way.Keep the belt on when doing it this way.
Old 09-20-2009, 01:12 PM
shawcross shawcross is offline
well seriously it doesn't matter what brand of part u put on and to think it will last longer it a joke
Old 01-17-2010, 08:19 PM
jds1vette jds1vette is offline
I just replaced the water pump on my 1998 5.7L. That clutch fan nut was a bitch. I didn't even know about when I started but I looked up a few threads and it seemed like no one even knew which way to loosen it. Anyway, I took off the entire water pump with fan attached, then literly destroyed the old water pump. It unscrewed normal right hand thread, counter-clockwise. I sprayed penetrating fluid and let it sit an hour. I had to put it in a vise and hit the wrench with a 3 lb sledge 20 times before it broke loose. Without that goofy nut it would have been a very easy job. I see there is a special tool to hold the fan...I sure could have used that.
Old 01-18-2010, 05:40 AM
Blue Bowtie's Avatar
Registered Offender
A quick search of the board archives would have revealed that it is a RH thread, and that a 1-5/16 wrench would fit it (or 32mm). The fan clutch hub is best broken loose with the accessory belt still in place and a strap wrench to help restrain the pump pulley while tapping on the wrench with a dead blow hammer.
http://www.automotiveforums.com/vbul...d.php?t=894243
http://www.automotiveforums.com/vbul...d.php?t=661049
http://www.automotiveforums.com/vbul...d.php?t=294756
http://www.automotiveforums.com/vbulletin/t191246.html
etcetera...
Old 01-18-2010, 06:07 AM
I have a 32mm wrench it was too small so I used a giant adjustable wrench. I think it's a 36mm.
Old 01-18-2010, 01:09 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Obviously you havent done alot of water pumps. I can say that I have had to warranty out pumps of all brands but I found napa and federated are good and maybe advance in a pinch.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 01-18-2010, 04:52 PM
the quality of any re-built part is very questionable in todays world..
Old 01-18-2010, 06:02 PM
kahjdh's Avatar
I only do new, for like $5 there is no point especially if I have to take the timing belt and half of the engine off to get it.
Current Cars:
Past Cars:
Old 01-18-2010, 06:20 PM
if the pump is an alloy metal NEW ONLY ...
