Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 09-15-2009, 04:36 PM
08 lukas 08 lukas is offline
ABS.Brake and TCS are on
wondering why these lights would all stay on?
Old 09-15-2009, 08:32 PM
roadrunner2 roadrunner2 is offline
Re: ABS.Brake and TCS are on
Both systems work together.
There may be a faulty ABS wheel sensor (possibly just a loose wire).
If the problem is the sensor the complete wheel hub will have to be replaced. I had to do it with the 2000 Silo I had.
The problem with doing nothing is not knowing when you're finished.
Old 09-28-2009, 02:08 PM
dewaynep dewaynep is offline
Generally speaking a wheel speed sensor would not cause the "brake" light to come on also. ABS and TCS lights will come on with a bad ABS sensor. What I have found is it is usually a major malfunction in the EBCM (electronic brake control moduele) that causes all 3 lights to come on. It doesn't mean your brakes won't work, it does mean you won't have abs or tcs. I also know in NY it won't pass inspection with the brake light on. The other 2 (abs and tcs) will pass fine. You really need to scan the brake system and find out what is going on if you want to repair the problem.
Old 09-28-2009, 06:25 PM
Jrs3800 Jrs3800 is offline
If this is a 90-96 Version, and there is an issue with the wheel speed sensor the ABS, Brake and TCS will light... Its very possible that its a bad wheel speed sensor, but you should have the codes pulled to determine what fault or faults the EBTCM are seeing...
Just out of curiosity, what year are we talking about?
Old 09-29-2009, 10:44 AM
Sandfobs Sandfobs is offline
Send a message via MSN to Sandfobs
I have the same problem with my 98 Sileouette all three lights are on and I have plugged in a code reader and it says No DTC's found. I assuming scanning the brake system would show up but the lights are on and nothing is showing up.
Old 09-29-2009, 10:55 AM
Not just any scan tool, it must be able to access the abs system. Not all scan tools can, in fact most can't. You would need a snap-on brick or Mac determinator or OTC genisys or better.
Old 10-31-2009, 09:39 PM
463's Avatar
463 463 is offline
nine times out of ten there is a broken wire at the front left or right wheel right where the wire comes out of the loom tube on the lower control arm or lower ball joint area thats causing the system to not work (light on). http://www.automotiveforums.com/vbul...d.php?t=928855
Old 11-08-2009, 02:03 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Have you checked the rear boards? (The part that holds the rear brake bulbs behind the taillight lenses.) If they are corroded as is a major issue with these vans, that can cause the lights to come on. The same thing happened to both of my vans, and when I replaced the boards, the problem disappeared. (Is your cruise control functioning? If not it also is a sign that the boards are corroded.) If the problem is minor, a simple cleaning might take care of the problem. If it has progressed, then replacement is necessary.) The boards can be purchased rather inexpensively on eBay. A listing of some of these boards available on eBay can be found here.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
