Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 09-13-2009, 07:08 PM
hregent hregent is offline
Question I need help!
I am trying to figure out what you call a part under my car its between the oil pan and transmission pan it has a wire connector leading to it and when you unplug it the car shuts off it is making a rattling noise that makes the car sound like a diesel is it the flywheel?
Old 09-13-2009, 08:36 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: I need help!
I have a couple of suggestions. First, take a photo of it and link to the photo here (can use a free photo sharing service such as Photobucket, etc.). Second, use punctuation in your posts like you agreed to do per the forum guidelines.
The flywheel will not have an electrical connection to it, it is purely mechanical. The starter motor connects to the flywheel teeth during a start event, but I don't think you'd be able to unplug any of the connections to it when the car is running that would cause the engine to stall.
-Rod
Old 09-14-2009, 05:46 PM
Re: I need help!
I tried to post this pic, can you please let me know if it works,and if it don't can you please give instructions.I signed up with photobucket just to send the pic.I took pictures yesterday so i could try and find out what this was.
Old 09-14-2009, 09:12 PM
shorod's Avatar
SHO No Mo
Re: I need help!
It worked for the most part. The link was good, but the code didn't past in quite right. For future image posts you'll want to use the code within the parenthesis, ""
Unfortunately I took a look at the photo and I don't recognize it. It appears to be a hall effect sensor on the flywheel, but I'm not sure why it would be there. I don't see a similar sensor on my wife's car. Is your LS a manual transmission?
-Rod
Old 09-14-2009, 11:05 PM
302NOVA 302NOVA is offline
Re: I need help!
That's prolly the crank position sensor! Check Rock auto for a picture to see if it matches!....302NOVA
Old 09-15-2009, 06:28 AM
shorod's Avatar
SHO No Mo
Re: I need help!
That would help explain why the car would stall when it's disconnected, but I don't know why they would mount it on the flywheel rather than the crankshaft since the same engine is used with the Automatic transmission and in that case they mount it on the crankshaft. Plus, they'd need to index the flywheel then so the sensor would know where TDC on cylinder #1 is. That's extra effort when a mount and tone ring is already engineered at the other end of the crankshaft.
Since unplugging the sensor caused the engine to stall, there is probably a diagnostic code that's been set. You could have the PCM scanned for stored codes to see what it indicates. If it says there's an issue with the CKP signal or similar, then 302Nova is likely right. The factory service manual shows the CKP connector on the front of the engine and doesn't distinguish between Automatic or Manual transmissions. Unfortunately, without know what that part is, it's difficult to find in the service manual.
-Rod
Old 09-15-2009, 01:23 PM
danielsatur danielsatur is offline
Re: I need help!
I was actually thinking of an engine running or crank pos sensor to the PCU.
Working with both electrical & pictorial schematics on old school TV's canbe a pain!
Changing the Package and pos of a sensor on a new cars is
like having to buy a new tool to remove a bolt.
Old 09-15-2009, 03:42 PM
Re: I need help!
It is a V8 automatic.Do you know why the flywheel would be making a noise,that makes the car sound like a diesel? Should i replace it now instead of waiting til the car breaks all the way?
Old 09-15-2009, 05:02 PM
Re: I need help!
Whats the year + mileage on this car?
Is it more like a Dodge Ram with a noisy rattle?
Shut engine down ASAP, befor you need a new motor.
http://www.automotiveforums.com/vbul...d.php?t=954555
Also use Automotiveforums > lincoln > LS
search forum tool ''Cam chain''
Old 09-15-2009, 11:59 PM
Re: I need help!
It's a 2000 model with 135,000 miles and the only thing i have changed is the battery and alternator.I've had the car about 3 years now it's been fine except for the missfire thing that seems to be a common thing on these cars.I would say the noise is like a volvo! but it sometimes is quiet and at times sounds like i'm driving a truck (while idiling)not when driving.I have learned so much from this forum and appreciate the feedback.
Old 09-16-2009, 06:19 AM
ronaldk's Avatar
ronaldk ronaldk is offline
Re: I need help!
Jeep uses flywheel to get timing from CPS so I also think that is CPS. The thing I see in pix is that open area.Usually that is a inspection area and would be covered by inspection plate,that seems to be missing. If any foreign object got into flywheel area (like small stone) could cause noise and problems.I would also check the torque converter bolts to flywheel since inspection plate is off.Also check to see if starter is loose,since your real question is what to do about noise correct?
Old 09-16-2009, 07:09 AM
Re: I need help!
Jag S Type has the same issues as Lincoln LS, and they both canbe fixed.
If your car is misfiring, a damaged Catalytic converter will amplify noise.
See Troubleshooting Misfiring.
http://www.automotiveforums.com/vbul...d.php?t=882939
Because of Age + mileage, I would put my money on BAD secondary cam tensioners.
The 1st type of tensioner would wear out, and derail the cam chain.
Caution - This is Interfearence type engine, the valves will bend.
Can you can isolate the noise on the R or L side of engine?
How many miles did the car have on it, when you bought 3 years ago?
Is there any old service records given to you?
Old 09-16-2009, 04:32 PM
joegr joegr is offline
Re: I need help!
It is the CKP sensor. See link below. My gen IIs have these.
http://deneau.info/ls/s6x~us~en~file...tm~gen~ref.htm
