Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 09-03-2009, 03:13 PM
glatham glatham is offline
Avalon ECM fuse and codes 1133/1135
I tried pulling the ECM fuse with the car off and key off and the check eng light was still on when I restarted the car. What am I doing wrong? thanks again.
Old 09-03-2009, 05:11 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Avalon ECM fuse and codes 1133/1135
You are not doing anything wrong. You have a DTC from a problem which is detected immediately and you are getting a CEL as soon as the code is stored. Removing the ECM fuse only deletes codes that are stored. It does not prevent codes from triggering the CEL. Find out which codes are stored.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
