Old 09-02-2009, 08:35 PM
Ron21 Ron21 is offline
2003 Grand Am wont start when its cold outside
I have a 2003 Grand Am with the 2.2 L. When it is cold outside the car will not start. After warming up in the sun the car starts right up and runs fine. Any idea what would be causing this
Old 09-03-2009, 08:07 AM
3100 3100 is offline
Banned
Re: 2003 Grand Am wont start when its cold outside
just wondering in the morning when you turn the key to on position only water temperature gauge should show cold completely what is your gauge showing?
Old 09-03-2009, 11:45 AM
shows cold completely
Old 09-03-2009, 05:19 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
How old are the plugs ?
It also could be a vacum leak right off the intake.
1999 Grand Am SS 3.4 OHV
Old 09-04-2009, 10:44 AM
Plugs are brand new. Can't find any vacumn leaks
Old 09-04-2009, 12:23 PM
Banned
check your coolant level,
also you can try disconnecting your ect sensor and measure the resistance the ect is reading in the morning, then measure the water temperature. I will find specs for you and then you can compare it. Also did you gap sparkplugs? Also clean throttle body and iac passages
Temp / ohms
32 9420
41 7260
50 5670
59 4450
68 3520
77 2796
86 2238
Old 09-05-2009, 04:10 PM
Also might check your fuel pressure cold then again when its hot to see if the pumps building enough pressure cold.
