Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-31-2009, 07:58 PM
larrys 97 larrys 97 is offline
96 neon tranny problem
i have a 96 neon and after i drive it a while it wont down shift
Old 09-01-2009, 07:08 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 96 neon tranny problem
I am assuming this is an automatic?
2003 Dodge SRT-4
Old 09-01-2009, 02:03 PM
yes
Old 09-01-2009, 02:29 PM
Could be time for a fluid and filter change and adjusting the bands.
2003 Dodge SRT-4
Old 09-01-2009, 07:07 PM
thisnametooktolong thisnametooktolong is offline
so I take it that it is stuck in high gear all the time? or do you mean that it does not Kick down? I take it that if you start out after starting it it shifts fine until you try to slow down the first time? If the darn thing goes one, two three. Then shut it off to get it in first... fluid and filter aint guna help
what do you mean?
Old 09-01-2009, 09:52 PM
what do you mean?
it wont down shift
Old 09-02-2009, 05:25 AM
Adjust the throttle pressure control cable.
It is the same idea as a TV cable for GM, or fords old kick down linkage.
Pull the pressure lock tab slide the cable all the way toward the engine. Turn the kick down lever clockwise, until it hits the internal stop. Replace the locking tab, and let go of the lever. It should be adjusted. Take the car for a test drive it should be OK unless some thing is broken or worn out
Old 09-02-2009, 07:32 PM
its down shifting ok now after i messed with it now it wont kick down into passing gear
