Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 08-26-2009, 03:49 PM
caribbeankruzer caribbeankruzer is offline
O4 Eating Rotors
My 04 now has 100k and I need to put my 4th pair of rotors on. It always comes down to a breaking viberation when stopping and it seems to be just over a year after I replace the rotors. Nothing appears to be worng with the calipers and everthing seems like the release of the pads should be fine. Is this just something to expect with this truck or should I repalce the rotors. I found some : http://www2.partstrain.com/store/det...Passenger_Side
Think I should try them or change the calipers?
Old 08-26-2009, 06:44 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: O4 Eating Rotors
Do you usually stop fairly hard? You may need to slow the vehicle down and not press so hard on the brakes. The rotors warp from heat--heat is caused by friction--pressure on pedal causes friction.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-26-2009, 06:53 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Some brake pads, particularly ceramic ones seem to be harder than the rotor steel... so the rotors wear out pretty fast.
Why are you replacing rotors, instead of machining them? Sometimes, some cheapo rotros do not have enough material in them to allow for machining. Try a better (more expensive ) rotor next time.... or just live with the problem.
My '97 Deville has much the same problem as you. But the cheaper rotors cost about the same as machining them.... so I just buy new rotors every time.... no problem.
Old 08-26-2009, 09:20 PM
wafrederick wafrederick is offline
Banned
Also inspect the fins of the rotors,pitch and get new ones if they are fully rusted out.I have been seeing this and it was all 4 on a 2003 AWD Chevy van last time.
Old 08-28-2009, 08:47 AM
rhandwor rhandwor is offline
If high mileage buy rebuilt calipers. The rubber in the caliper seal pulls back the piston slightly after stopping if the rubber gets old they will hang up.
http://www.popularmechanics.com/auto...27.html?page=2
