Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 08-22-2009, 05:54 PM
Dawgfan Dawgfan is offline
Question Need info on rear window
1. Has anyone replaced the rear window?
2. Where did you get the rear window?
3. Can you go to a store that sells plexi-glass or will I need to go to PAD for the window?
4. Has anyone put holes in the rear window? If so, what location, size and how many?
5. Am I right in think that if I put holes in the rear window it will cut down wind resistance and decrease drag?
Old 08-22-2009, 07:55 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Re: Need info on rear window
Not yet, but we will be doing it eventually as no amount of polishing will remove the haze.
We were talking w/ wire wheel about it. It's not a PAD specific part so well just be getting it from CV Products where we got our front one and cutting to fit.
Any place that sells lexan windshields can source it for you.
I'm actually doing it tomorrow. I'm using my 2 1/4" hole saw and going to do 7 evenly spaced ones alont the bottom and maybe a couple at the top corners. I'm using the GT2 car on Wirewheel.com as a guide.
Not sure about wind resistance, but we want air flow through the cabin. Currently the shape of the car results in no wind flow in the cabin. I've got 2 clear naca ducts to install. Coupled w/ the holes it should promote some nice air flow through the interior.
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 08-23-2009, 06:03 AM
Thanks for the info Cobra. Got to go to R A and run the HSR race this morning, I will get back to you tonight or tomorrow and see how your installation goes.
Old 08-23-2009, 07:39 AM
Squerly's Avatar
Squerly Squerly is offline
Good Luck Mike!
Squerly
Old 08-23-2009, 07:44 AM
David Eastman David Eastman is offline
Dawgfan,
We missed you yesterday in the padock but did see you pass on the BMW in 10a good job on the late brake into that corner.
David
Old 08-23-2009, 03:14 PM
Thanks, I passed that BMW 3 times going into 10A and had the line going into 1 2 times and the guy would not lift and I did not want to wreck a real good BMW. The guy block me on the back stretch(I guess that's the mentallity of a BMW driver). I must admit I had a real good weekend. I ran my best times ever @ 1:39 and the car is really running good. I hate that I did not see you in the Padack but hope to see you and everyone next weekend.
Old 08-24-2009, 09:03 AM
wirewheel99 wirewheel99 is offline
Well done this past weekend Mike.
Brian FYI..the two holes in the top corners of the GT2 car are for fuel dry breaks..
We just used lexan sourced locally for the rear window. I to doesn't really need to be anything special as it is on the back of the car!
James
www.wirewheel.com
Old 08-24-2009, 12:10 PM
Cobra4B's Avatar
James
www.wirewheel.com
Yeah I saw that... I'm just doing a row along the bottom for now. Going to bring the hole saw w/ me to VIR and experiment if needed.
Old 08-24-2009, 09:35 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
I did the holes in the rear window - it definitely cuts down on the wind inside the cabin, can't really tell if it increase flow thru though....
I was also just considering purchasing a small sheet of Lexan from Lowes - they sell them just barely large enough for the rear....but vision may soon be a non-issue, I have a new idea that I am toying with for rear view...gotta get the engine swap done first..
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 08-24-2009, 10:07 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Mike, the material you want is Lexan MR10 in 3/16". That stuff is UV resistant and has a coating on it. A few of us got together to purchase via a guy that works for GE. I used the original window to roughly trace the size. After trimming to size, I taped the lexan leaving ~2" around the edge of the lexan exposed. Then I painted the underside of the lexan black so when installed it hides the plastic roof portion of the body underneath. I secured it with fresh button heads and it came out great. I have not drilled holes in the window but I think I may space the bottom of the window up with spacers to test the effects of relieving pressure back there.
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 08-25-2009, 06:48 PM
Thanks for all the info from all of you. After this weekend, if we do the Chin event I will start the change on the rear window.
Old 08-25-2009, 07:54 PM
Squerly's Avatar
What do you mean "IF" you do the Chin event?
Squerly
Old 08-26-2009, 05:01 AM
I may not run but will come by to see everyone. Just not sure yet.
Old 08-26-2009, 08:03 AM
Squerly's Avatar
Come on man... we won't make you back up that 1:39 claim ...
Squerly
Old 08-26-2009, 05:40 PM
Will probably be there. I will have to put the good tires on to do the 1:39 thing again.
