Old 08-18-2009, 08:14 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Header Bolts Vs. Studs
So which do you prefer and why. I'm looking at a set of header bolts that will not back out but I'm hearing that bolts have a tendency to snap. Should I stick with studs?
Old 08-19-2009, 06:23 AM
thisnametooktolong thisnametooktolong is offline
Re: Header Bolts Vs. Studs
there are some variables
Technically speaking studs are stronger than bolts. That is why they use them in race applications. When you torque them to spec you do not twist the entire length of the bolt, so when it is all said and done they hold better. Can reach farther in the block holding the tolerance better. They also don’t tend to snap inside the block because the major force is on the outside not the inside. If the stud is not bottomed out at the top or the bore they do not snap.
BUT a very big but
After you have properly installed the stud, IT IS a pain in the ASS to get all those holes to line up when installing headers, heads, and the like. The more studs the bigger the problem. This is a big issue if you are trying to install a manifold that is in the car and has an exhaust plumed to the manifold.
Studs and bolt all snap especially when dealing with the seasoning that an exhaust creates. And after you initially break the rust…with a stud,. You now take a chance of snapping the stud as you try to get the nut past that nasty, rusty stud( if the stud is bottomed out). They all suck. When dealing with an old engine I just cut of the bolt/stud, remove the manifold, and the remaining piece usually unscrews with your fingers.
Old 08-20-2009, 11:12 AM
Polygon's Avatar
The Red Baron
Lucky for me the engine will be out when I do this. My issue is that it will not be very accessible when it's all put together and back in the car. I'm just not looking forward to retightening the studs after a few heat cycles.
Old 08-20-2009, 08:08 PM
if using good quality studs or bolts with good gaskets it is never a problem with re-torquing
Old 08-21-2009, 08:07 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Depending on the car, I prefer bolts simply because studs require a deceptively large amount of room to get the headers off. It might not seem like much, but many cars don't have the room to slide the headers straight out 1" to get them off the studs. Its not a big issue out of the car, but the first time you get a gasket leak you might be kicking yourself.
Dragging people kicking and screaming into the enlightenment.
Old 08-22-2009, 10:22 PM
Polygon's Avatar
The Red Baron
That's the issue right there. It's an I4 and the only way to get off the header would be to remove the head.
For reference, here's the bolts I'm talking about:
http://www.summitracing.com/parts/PHP-20100
Old 08-23-2009, 08:03 AM
curtis73's Avatar
I haven't used those Percy's bolts, but I've heard great things about them. Go for it.
