Old 08-14-2009, 07:32 AM
chevyguy10 chevyguy10 is offline
cavalier flooding
My daughters 1997 Cavalier got partially flooded last week and the floor is still wet. Now all of the dash lights are on. It starts and runs fine. Could the on board computer be wet. I'm not sure where it's located.
Old 08-15-2009, 10:04 AM
Blue Bowtie's Avatar
Registered Offender
Re: cavalier flooding
Yes, the PCM could have been immersed. On your '97, it should be located at the right front fender, just ahead of the wheel opening.
The electrical connectors are onn the lower edge of the PCM, and are susceptible to problems if the car is in more than a foot of water.
Old 08-15-2009, 12:17 PM
thisnametooktolong thisnametooktolong is offline
my car was in a flood, Did it get wet?
Old 08-15-2009, 02:05 PM
J-Ri's Avatar
J-Ri J-Ri is offline
That's really uncalled for. Obvioulsy it got wet, it appears he was asking the elevation of the PCM, since it was partially flooded.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 08-17-2009, 07:10 AM
Thanks for the replies. On the pcm since the engine runs but the dash lights are lit up is it possible the problem is in the connections or can part of the pcm fail but still allow the car to run.
