Old 08-12-2009, 08:52 PM
Wide_Track Wide_Track is offline
Found grease, CV boot
Hi,
I have a 1998 Grand Prix GT. There is approximately 230,000 miles on it. While looking into another problem, I found grease (not black in color; a slight olive color) on the back firewall, a beam (just below the boot), oil filter, and ¾ circumference largest portion of the boot. Was unable to locate the opening on the boot after cleaning it. But I do believe it probably the boot (no grease several days ago).
Never had a problem (i.e. no noise) with the joints and/or drive shaft on that side.
Is there a procedure to replacing the boot (adjacent to the motor; passenger side)? How long does it take to replace? Are special tools required? Also, any suggestions or comments are appreciated.
Thanks in advance,
Wide Track
Old 08-13-2009, 06:24 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Found grease, CV boot
See the link below.
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 08-15-2009, 10:14 PM
BNaylor,
Thanks! I appreciate the help.
Regards,
Wide Track
Old 08-19-2009, 10:02 PM
Hi,
Started working on removing the cv axle today. When I removed the axle about 4-5 cups of transaxle fluid came out. Is this normal?
Note: I do not believe this is a problem, but I had the car in neutral while removing the axle (allow me to find a good position to remove it).
Thanks in advance,
Wide Track
Old 08-20-2009, 12:59 PM
troy1 troy1 is offline
AF -Advisor
Having it in neutral is no problem as is loosing a little ATF.
Old 08-20-2009, 05:55 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
x2, normal. Just top off the fluid when you are done.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-23-2009, 09:27 AM
Thanks troy1 and tblake,
Completed. Was a little concern, anticipated less fluid.
Again thanks,
Wide Track
Old 08-23-2009, 10:04 AM
Thanks all for the help!
Wide Track
Old 08-23-2009, 11:04 AM
tblake's Avatar
In God We Trust
Nice work. Depending on the angle your car is sitting at and if you jack up just one side or both will determine how much (if any) fluid comes out.
