Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-28-2009, 03:38 PM
Meck46 Meck46 is offline
87 Caprice Classic brakes pulsate
Hi I have a 87 Caprice Classic with pulsating brakes when braking, I put new front rotors and pads, rear brake drums and shoes and it still pulsate when you brake, anyone have any idea what wrong.
Thanks Meck46
Old 07-28-2009, 08:31 PM
rhandwor rhandwor is offline
Re: 87 Caprice Classic brakes pulsate
Were the new rotors turned not all of them are true?
Old 07-28-2009, 08:41 PM
Hi no haven't, but I'm having them checked, and work from there.
Thanks for the reply.
Meck46
Old 07-29-2009, 12:22 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
When you put the new rotors on the car, did you clean them off first? They're shipped with a type of petroleum coating on them, to keep them from rusting in storage. It can be difficult to properly remove, but you must! If you don't, the rotors can develop localized overheating, leading to warpage and a pedal pulsation similar to what you are explaining. If the rotors are discolored when you inspect them, this will be your problem.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-29-2009, 04:04 PM
Hi yes I did clean them, I had them checked today and one was warped, I put the new one they gave me on and problem fixed.
Thanks for the help Meck46
Old 07-31-2009, 04:54 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
I found this to be true also.
It happened to me once when I was replacing rotors on a friends corvette, two of them were not true.
You would think that a new rotor would be true but i guess some slip past the quality control checker especially if they are on an egg roll and tea break over in china.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 07-31-2009, 05:18 PM
j cAT j cAT is offline
auto zone drums from china,,, seen these n/g out of box,,,autozone told owner these new drums need to be machined...!
Old 07-31-2009, 06:21 PM
Hi I noticed a note in the box the rotors came in, It said no further machining needed, with the inspection persons signature. So much for inspections.
Meck46
Old 08-01-2009, 01:42 PM
RageCage RageCage is offline
I used the Autozone Chinese rotor a few years ago. Got lucky, I guess. It was fine.
RC
Old 08-01-2009, 08:27 PM
RC
Ya with these chinese parts it's a CRAP shoot...
