Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 07-27-2009, 09:43 AM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Lets talk gearing... wasn't using 5th at VIR at all.
With a 6500 rpm rev limiter I was maxing out 4th gear in both staights on VIR full. The one trickey area was coming through oak tree. In 3rd I'd be too low in the rpms, but in 2nd I'd be over 6000 coming through. I ended up making my downshift from 4th to 2nd and just letting the motor howl... made for a much better exit speed etc.
These cars have 3.55 gears right? I'm thinking a 3.73 gear w/ a new trans w/ a revised 5th gear would be the ticket. I could come through the slower parts of the course in 3rd and use all of 5th on the high end. Thoughts?
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
Old 07-27-2009, 10:30 AM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Re: Lets talke gearing... wasn't using 5th at VIR at all.
Brain, that's odd, I am shifting into 5th shortly after the tower (south course) on the back straight.
But, I do like the idea of gearing change.
I was up there on Friday, forgot you were going or I would have searched for you.
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 07-27-2009, 10:55 AM
Cobra4B's Avatar
Were you able to get into UTCC? I didn't get there until Friday around 5:30. We've got the rev limiter set at 6500 and 314 rwhp. I could use 5th, but foud that I could just leave it in 4th. I was running 2:11-2:12s most of the time... what were you running?
Brian B.
Old 07-27-2009, 11:17 AM
Panoz26's Avatar
no, I went up to see a buddy and to post some flyers for my motor sale. I was sad that I did not sign up for the event, was a picture perfect weekend, 'cept for Sunday's heat.
My last run at VIR Full was when I still had the overly stiff springs and rear sway -- best time I could muster was a 2:15, theoretical based on TraqMate was 2:13/2:12's - so, times are close.
Old 07-27-2009, 11:27 AM
Cobra4B's Avatar
So are you finding that the mega springs you put in are too much? I've found that I love the rear swaybar.
What do you mean by "theoretical" when talking about the traqmate? I was looking at getting one, does it not measure lap times accurately?
Brian B.
Old 07-27-2009, 11:34 AM
Panoz26's Avatar
mega springs they were indeed. PM sent on the other.
Old 07-27-2009, 06:53 PM
PanozDuke PanozDuke is offline
They are 3.50's, the next option is 3.89 on the GTS cars. Your trans might have .82 5th, but could also have a .63 or thereabouts. There are 3.70 sets for the nine inch if you want to get close to 3.73.
Mike
Old 07-27-2009, 07:05 PM
panozracing's Avatar
panozracing panozracing is offline
3.89 is the ticket with a TKO600RR with the .82 5th....
go with bigger (taller and wider) rear tires too...
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 08-07-2009, 08:42 AM
Racer9007 Racer9007 is offline
Send a message via Skype™ to Racer9007
the 3.89 gearing works great in the GTS with the TKO 650, as for springs I like 750 front and 450 rears.
If you buy a different ring and pinion, dont forget to get one that is set up for the internal oil pump
Old 08-07-2009, 04:30 PM
Matt,
I'm ignorant of the internal oil pump in the rear end. Is that common to the GTWC and GTRA cars as well. How can I find out how it works? Thanks
Mike
Old 08-07-2009, 07:45 PM
there is an oil pump inside the rear end that is driven by the gears that pumps the oil outside the rear end thru a cooler and back in. TEX racing makes it.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 08-07-2009, 07:53 PM
NZGTRA17 NZGTRA17 is offline
Originally Posted by PanozDuke View Post
Matt,
Mike
No, the GTRA did not come with a diff cooler fitted as standard. Some cars may have been retrofitted though. To take out weight and negate the need for a diff cooler, I fitted an aluminium centre section case instead.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 08-07-2009, 07:57 PM
Gatorac's Avatar
Gatorac Gatorac is offline
I would think that a diff cooler would only be needed if you had something other then the open diff the RA cars have.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 08-07-2009, 09:15 PM
Kel.
Jim,
not sure that RA cars had an open diff from the factory. Mine came with a True Trac LSD and the optional 3.5 gears. The True Trac acts like an open gear set if you lift a wheel and turn it but when torque is applied it is a very efficient LSD unit that is perfect for our low C of G cars.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 08-12-2009, 09:12 PM
eric1h eric1h is offline
Brian, I was running 2:10-2:11'sat VIR last time I was there in Feb/March
I hit 5th gear about 1/2 way up the hill on the back straight, the front straight i barely used 5th, main reason i shifted into 5th was to smooth/ease the shift back down to 3rd into turn 1....
Hurry up and get your traqmate going and I'll send you some of my files.
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
